Possible to create Custom Panes?
Anyone know if it is possible to create a custom Pane? I want to ad my favorites to it, so I don't have to scroll through so many folders to get to commonly used figures, props, clothes, etc. Thanks.
  • hphoenixhphoenix Posts: 1,335
    edited May 2016
    Yes, it requires C++ coding an SDK Plugin.
    Or you can just create a 'Favorites' folder, and create links to all the files you want in it.
    Post edited by hphoenix on
  • IceDragonArtIceDragonArt Posts: 12,826
    You can set up custom categories quite easily.  Right click on the picture icon of the item you want to put in a favorites folder and choose categorize.
  • srieschsriesch Posts: 4,243
    Another option, if you are willing to use a menu rather than a pane:
    To quickly create a menu item to load a commonly-used content item:  right-click the content thumbnail and select "Create Custom Action". (These will appear in the Scripts menu).
  • Thanks. I think I'll go the Favorites Folder route. Just want the routine content used in one place, so that will work. Thanks again.
  • Peter WadePeter Wade Posts: 1,671
    How do you create a Favourites Folder?
    I use categories to organise my stuff but since I installed 4.9 my categories have started to go wrong. Perhaps I could use Favourites as place tp keep stuff that won't got into categories.
