Shape Shift for Genesis 3 (Commercial)
1234568»
  • Zev0Zev0 Posts: 7,123
    edited May 2016
    Simply dial out those morphs on the hair product to undo the auto follow shape. Or instead of autofitting, just parent hair to figures head and scale and add a little smothing. That way hair is not affected by body changes.
    Post edited by Zev0 on
    hi Zevo, i purchased the Shapeshift morph package and after installation, couldn't launch the script.  Log file error "WARNING: libpng warning: iCCP: known incorrect sRGB profile"
    i'm new to Daz so i'm probably asking you a rookie question, but hey...that's how i learn.  any help is appreciated.
    Cheers,
    Can you send a ticket to Daz? I have no Idea what that error means. ShapeShift does not use any script so I don't think that error is product related.
  • cosmo71cosmo71 Posts: 3,609
    edited May 2016
    Cheers,
    I think he has installed the shape shift product while he worked with DS and his Character and has tried to inject the morphs via double clicking on an icon. Shape shift is first activ after new loading the character.
    Post edited by cosmo71 on
    Well hair but just paranting is also not an option for long hair (movements) Well yeah will try some things, maybe it is on the hair products, I have hair products that causes bad results if I use the abdomen width morph but the hair has the bad result at the upper chest region, I do not know what the addomen width has to do with the upper chest region but okay (and it is the abdomen morph, I tested it)
    Cheers,
    Have you had DS open and the character loaded while installing shape shift?
    Reason for this question is. Shape Shift will automatically load to your figure when the figure gets loaded new after installing the shape shift product.
  • murgatroyd314murgatroyd314 Posts: 1,569
    Just wanted to give some belated thanks for this, and a tip:
    With very few exceptions, G3F shapes can be improved by setting Belly Shape Fat 2 to about 20%.
  • 2sharp2sharp Posts: 54
    I ourccased this produt 2 days ago and only received 12 ZERO shpes. I uninstalled it and installed it again. Same results.
    The product description says there are 141 morphs.
    How do I get them?
    I looked for the Produt ReadMe mentioned in the description to see if it would be of help but did not find one
    Many thanks for your help,
    Giovanni
    The morphs are located on different parts of the body. Either search for them via the Parameters or Shaping Tab.
    905 x 341 - 220K
  • colinmac2colinmac2 Posts: 407
    Zev0 said:
    Aging Morphs will still be released. The only things I took from it was the Spine morphs:) If all goes to plan the new Aging Morphs will have a new feature I am experimenting on. A bit ambitious but if I can pull it off, will make it really cool.
    /drool.
