Adding to Cart…
Simply dial out those morphs on the hair product to undo the auto follow shape. Or instead of autofitting, just parent hair to figures head and scale and add a little smothing. That way hair is not affected by body changes.
Can you send a ticket to Daz? I have no Idea what that error means. ShapeShift does not use any script so I don't think that error is product related.
I think he has installed the shape shift product while he worked with DS and his Character and has tried to inject the morphs via double clicking on an icon. Shape shift is first activ after new loading the character.
Well hair but just paranting is also not an option for long hair (movements) Well yeah will try some things, maybe it is on the hair products, I have hair products that causes bad results if I use the abdomen width morph but the hair has the bad result at the upper chest region, I do not know what the addomen width has to do with the upper chest region but okay (and it is the abdomen morph, I tested it)
Have you had DS open and the character loaded while installing shape shift?
Reason for this question is. Shape Shift will automatically load to your figure when the figure gets loaded new after installing the shape shift product.
Just wanted to give some belated thanks for this, and a tip:
With very few exceptions, G3F shapes can be improved by setting Belly Shape Fat 2 to about 20%.
I ourccased this produt 2 days ago and only received 12 ZERO shpes. I uninstalled it and installed it again. Same results.
The product description says there are 141 morphs.
How do I get them?
I looked for the Produt ReadMe mentioned in the description to see if it would be of help but did not find one
Many thanks for your help,
Giovanni
The morphs are located on different parts of the body. Either search for them via the Parameters or Shaping Tab.
/drool.
