3 easy tricks - Enhance your Hardware renders and previews
mCasualmCasual Posts: 4,607
edited May 2016 in Freebies
First you have to go in Edit/Preferences/Interface and turn on the "Per Pixel Shading" option
Trick 1, get Ambient/Self illumination to work
You will notice that when "Per Pixel Shading" option is On, you lose the Ambient channel's usual effect
so, for the red hair here
1 - set the Specular channel to White ( or try with colors or try with texture inmages ), Specular Strength at 100%
2 - set the Reflection Strength to 100%
there you go ! the material now self illuminates!
Trick 2, Chrome and Gold  effects
As you can see on the Trooper-Aiko3, we can have fake chrome/reflective effects in Hardware renders and the 3D Viewport
1 - set the specular color to white, strength 100%, set glossiness at 100%
2 - set Reflection color white, strength 100%
3 - apply an image to the reflection color channel
in my case i applied a 360 degrees panoramic photo of a beach from sIBL archive
when i want to make gold metals, i use an image like this and i add a gold tint to the reflection color and/or the specular color
Trick 3 get a Live ! Environment Sphere/Dome
1 - create a huge sphere, example, 100 meters diameter
2 - lower the sphere until its center is at ground level, in my case it means move it 5000 centimeters down the Y Axis
3 - set the specular color to white, the specular strength to 100%, the glossiness to 100%
4 - apply a spherical image to the specular color channel
5 - set the reflection color to white, reflection strength to 100%
There you go ! Note that the effect works best if your camera stays close to the center of the  sphere
the default iRay environment image that comes bundled with Daz Studio 4 works for this purpose, find it in your folders :
C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr
the sIBL is my great rresourcefor those 360 panoramas ( called spherical or equirectangular format )
http://www.hdrlabs.com/sibl/archive.html
Post edited by mCasual on
  • MilosGulanMilosGulan Posts: 1,993
    Thank You so much mCasual, tips 2 and 3 are great. I will have to try using those spherical panoramas in my pictures.
