Soap suds or foam?
jdavison67jdavison67 Posts: 690
edited April 2016 in The Commons
Anybody seen any good textures or props for soap suds or soap foam?
I wanted for both skin and water surface.
I was surprised not to find any hits when searching for this.
Wanted to do something where a character was washing dishes in the sink...but am having trouble with the entire setup.
JD
Post edited by jdavison67 on
  • mtl1mtl1 Posts: 1,508
    Soap bubbles and suds are particularly hard to render properly because it has a bunch of volumetric effects along with gloss/spec. There are a couple of post-process products, one being Ron's suds as photoshop brushes.
  • DollyGirlDollyGirl Posts: 2,718
    edited April 2016
    Spacebones has a set of objs that include foam and bubbles. You will have to set up your own textures but at least you have the objs. http://www.sharecg.com/v/25522/View/5/3D-Model/Liquid
    Image shows the bubbles and foam used in 3Delight. Hope this helps.
    1000 x 1294 - 479K
    Post edited by Chohole on
  • MarshianMarshian Posts: 1,465
    Yes! This will be an expanded usage of a new product of mine that will be in the store in 2-4 weeks.
    ...stand by!
    ...almost here!
  • CybersoxCybersox Posts: 10,012
    edited April 2016
    ...stand by!
    ...almost here!
    Iray & 3DL or Iray only?
    Post edited by Cybersox on
    edited April 2016
    There have been a couple of "foam suits" made for Poser that that can work okay in 3DL, like Powerage's Foam & Soap and Ironman13's i13 CV01, both over at Renderosity, and Adam Thwaites has a free soapy skin as well as a free foam bath prop at Most-Digital-Creations.
    This one will be Iray only but a 3DL version could be possible a bit later.
    ...stand by!
    ...almost here!
  • srieschsriesch Posts: 4,243
    I don't have it, but Ron's Suds ( http://www.daz3d.com/rons-suds ) exists.  It's 2D.
  • vwranglervwrangler Posts: 5,053
    edited April 2016
    ...stand by!
    ...almost here!
    @Marshian you might want to talk to your erstwhile partner in business, Sickleyield, if you're going to do something with the Spacebones objects. I know she set them up for 3Delight at one point a while back.
    Post edited by vwrangler on
    Oh Yes Spacebones, I still have those! The product I'm refering to here is a brand new sculpt. The main usage doesn't actually look much like bubbles at all but a few little tweaks and its there. I discovered it almost by accident.
    The same sculpt/model can be used for 3DL and I may be able to use some of the maps but converting it from Iray is going to take a lot of work on the surfaces.
  • em53em53 Posts: 32
    If you have the V4foamsuit by Powerage,you can apply to a Genesis 2 or 3 geoshell in the diffuse channel. Then apply the appropriate transmap in the cutout opacity and set opacity to 0 for areas without suit (e.g. face) Looks really good, all nice and soapy. ;-)
  • jdavison67jdavison67 Posts: 690
    ...stand by!
    ...almost here!
    WOOHOO!
    YAY!!!!!
    Thanks!
    edited May 2016
    Ok, Here we go....foam party!
    I discovered this while testing my new product: Above the Clouds for Iray: Nimbostratus
    There was nothing at all to adjust materials beyond default settings for this image. Of course a massive reduction for the scale at .46%. The cloud prop is round so it will work great for glasses, mugs, and...fountains?
  • ScavengerScavenger Posts: 2,677
    So that's a cloud reduced in size?
  • RuphussRuphuss Posts: 2,631
    first glance says
    how does she get out of that stone ?
  • argel1200argel1200 Posts: 760
    @Marshian: Wow, I never would have thought of trying that out. I can see why you stumbled across it.
    I dont think she wants to, ha.
    Ruphuss said:
    first glance says
    thats right, with no change in materials. It is scaled down to .46% and stretched a little to fit the tub.
    Always my goal to find more freedom in uasge. Originally I included the tub render in my promos but the team didn't think it was a good fit. That decision makes sense to me now especially knowing that when the product was released I could finally post in this "suds" thread.
    Hi Marshian, is the cloud prop "bubbly" from geometry or a tiled displacement map? If it's the latter, I'd imagine the use case could be extended to poofs of foam as well.
    Yes Rons Suds are real and look great if I say so myselfimage
    500 x 650 - 236K
    It is both actually, in the promos you can see a render of the model without any texture. The texture is tiled so you can somewhat adjust the size of the poofs/puffiness.
  • Where i can get soap and foam for G8,1 female?
    Should work on 8.1 https://www.daz3d.com/iray-foam-and-bubbles
