Stonemason Dirt Shader for Iray
I really loved using this. Is there an Iray version?
There is A Touch of Dirt for Iray. It is not quite the same as the Stonemason shader. There is a thread showing some uses of it here.
Thank you very much. Looking at it right now. It was just that I really loved the way the Stonemason worked with the geometry. It looked so real.
Good luck on that. If you do succeed I will be first in line to buy it. It would be awesome if you could make a 'wear' shader which would varying degrees of wear on raised edges.
