Stonemason Dirt Shader for Iray
I really loved using this. Is there an Iray version?
    There is A Touch of Dirt for Iray. It is not quite the same as the Stonemason shader. There is a thread showing some uses of it here.
  • SigurdSigurd Posts: 1,095
    Thank you very much. Looking at it right now. It was just that I really loved the way the Stonemason worked with the geometry. It looked so real.
  • Oso3DOso3D Posts: 15,129
    Yeah, I've thought about how that would work in Iray. I don't know 3dl or Iray quite well enough to figure out how to replicate it. I'm not sure how to work out 'angle of surface.' Hmn. If I ever figure it out, though... will make it. :)
    Good luck on that. If you do succeed I will be first in line to buy it. It would be awesome if you could make a 'wear' shader which would varying degrees of wear on raised edges.
