Puh-leeeeeease PAs.....
Damsel
in The Commons
The one male item I really, really want is a pair of riding boots. There are combat boots, other kinds of boots for M7, but I really want those knee boots like motorcycle cops wear. Or polo players. Somebody made a Nazi SS uniform with those boots, but, well. Nazi. M4. Ack. I auto fit them, but they looked a little weird. And, well, Nazi.
I react to a man in those boots and tight black pants the way men react to a girl in a French maid costume.
Don't judge.
You ask them to make sure they dust along the top of the doors next time?
*snort* Bwahahahahaaaaa.....
Not judging... that was just funny. :)
LOL!
Try the boots from Wolf King (either Genesis or G2M)
Those are my go-to boots for that style, and they autofit well to G2F. I haven't tried fitting to M7/G3M
Edit - or see if the boots from the Peasant Outfit for G3M will work for you.
This set has riding boots: http://www.daz3d.com/riding-habit
Thank you for the tips. I own both those, I think.....
As for judging...
I'm not that interested in the tops of doors, but a good biceps bunch will always rivet my attention.
Biceps can be useful for what you really need:
https://youtu.be/zsBBz353UGU
Wilmap made a riding outfit set for Genesis 1. Try here: https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=70
Depending on how much decoration you want, and if you don't mind autofitting/transfer utility, and how much you're willing to spend, these might also work:
http://www.daz3d.com/biker-bandit-for-genesis-3-male-s (may be shorter than you want)
http://www.daz3d.com/dead-nation-boots
http://www.daz3d.com/lone-wolf-for-genesis
For Dead Nation and Lone Wolf, you'll need to use "full body" instead of "footwear" for autofit/transfer utility, because the boots come up too high on the leg for the footwear projection morph to cope.
The other trick to converting Genesis clothing to later generations is that you need to turn the smoothing WAY down. For example, Dead Nation boots have a default smoothing value of 20; that should be turned down to around 3, with collision iterations of either 1 or 5 or 7 (can't be 3 because it can't be the same as the smoothing value because then smoothing/collision fails to work at all). If you don't do that, and you save the scene, the next time you open it up, the boots explode.
The material sets also convert reasonably well to Iray, if you're using that. And, of course, that's not an issue with Biker Bandit.
Do these boots help?
http://www.sharecg.com/v/80023/view/21/DAZ-Studio/Ghastlys-Space-Cowboy-Genesis-1
