Bend Control for Genesis 3 Females and Males (Commercial)
135
  • JeffGJeffG Posts: 125
    Hearing the Heinz "Anticipation" song...
  • Stryder87Stryder87 Posts: 899
    I don't even bother to see what the product is anymore.... as soon as I see Zev0 I just pull out my credit card....  laugh
  • takezo_3001takezo_3001 Posts: 2,044
    edited April 2016
    There needs to be an upvote system here...
    EDIT: IT'S HERE! I never bought something as fast in my entire life!!
    Thanks ZEV0!! It's mine, finally! Mu-hahahaaa!
    Post edited by takezo_3001 on
  • Zev0Zev0 Posts: 7,123
    Thanks for the patience and support guys. Hope you like it and find it useful.
    You're welcome, sorry if I got carried away there, but I have been waiting for this solution ever since the first genesis came out!
  • MasterstrokeMasterstroke Posts: 2,512
    Looks as promised. Very happy with my purchase. :)
  • CybersoxCybersox Posts: 10,022
    I'm holding on this as I suspect that the sale prices that are being shown in the store are currently incorrect.  Grrrr.  I really want this NOW.
  • Sensual ArtSensual Art Posts: 646
    What's the issue? I just bought it for 41% off.
  • KA1KA1 Posts: 1,012
    edited April 2016
    The price was showing fine for me this morning but has gone wrong now, it's showing full price in the store and in my cart :(
    *edit - It randomly fixed itself now!
    Post edited by KA1 on
  • KnittingmommyKnittingmommy Posts: 8,191
    Yeah, me, too, usually.  I am always recommending Zev0 products to anyone who asks my opinion as I find them indispensable.  In fact, I did that just the other day.  I'm a little bummed that I have to wait a little while for this one and one other product that came out in the store today.  I don't dare put anything else on the CC for now.  On a bright note, it is the only Zev0 product I won't own so I'll get a chance to save some money when he comes out with his next great big thing!  I just hope that isn't immediately while the CC recovers.  Unfortunately, for now it has to go on the wishlist.  I do have to say it looks great and it will most definitely be a must buy once I'm buying again.
    And then some, as there is much more than the legs and glute that's in play here, wow all these morphs just to function as one simple knee bend!
  • cosmo71cosmo71 Posts: 3,609
    edited April 2016
    Bend Control for arms and overall for armpits and chestsites would be a good thing. If the character is a bit more chubby (if using the body size morph) the arms got much to big and even with negativ values for the arms it looks not really good from behind. So a bend control for the upper arms (arm width and armpits would be a good thing I think.
    extremly necessary is the armpit morph especially for the back armpits and each side should have its own morph nexto a "both" morph.
    Also a morph for widen/narrow the inner upper arms, not the depth but the width
    Post edited by cosmo71 on
    edited April 2016
    Something like that has being drafted, don't know if I really want to tackle that right now because it is a mess regarding all the different shapes and I will need to plan it properly, but for now my focus is on Aging Morphs 3. I will fill in the gaps as best as I can after the schedualed main products are out.
    Post edited by Zev0 on
    edited April 2016
    Question:
    What do I have to do to let the shin compress morph jumps in earlier, means at a lower bend value of the shin? Or an update with a "flatten calves" morph for example.
    edited April 2016
    Just bend shins slightly while Leg bend controller is on, and up the values on both legs. It will now remember that strength in relation to that bend value. Oh I forgot if you use the zero presets, it removes any manual work you did. eg morph strength editing.
    possible to use the calves bend morphs without the leg bend controller ? I have recognized that I can use the full range of all morphs manually just if the leg bend controller is higher than zero, so also at 0.1. the thing is that I like the idea of an automatically bend control for the legs but to have good results on the calves for example I have to raise the leg bend control so high that the thigh morphs collide with some of the morphs of your shaping product for g3f (thighs apart or thigh outher morph or thigh thickness morphs for example) or I raise the value for leg bend control just to 0.1 and do all manually, but this well is not the idea of an automatic. As written before my character is not one of these slim and skinny ones.
    BTW the product itself is really good, the hip bend control is great and works really good with another 3rth party glute control I have bought at another store.
    edited April 2016
    The morphs are designed to unlock only while the bend controller is active. You can manually unlock and unlink it as well where it will then behave as a standard morph not dependant on the controller. Too be honest it is actually better just to set the bend controller at a low value such as 0.1, that way the morph links stay intact. The result will be essentually the same since you are setting it's strength manually anyways.
    what I do not like is that the thighs move backwards if I use the leg bend control, why not just some morphs for the calves?
    edited April 2016
    at first view this product looks very usefull for my needs unfortunatelly it is not right now because I get unwanted results in combination with some third party morphs I really need and poses I have already saved in my own pose folder and I don`t see my adjusting nearly 100 poses and some third party morphs I really need, so right now I can`t use it the way it is with its automatic bending morphs and I don`t see my searching the tons of morphs for manually adjustments for one pose and then the next time for another pose and so on.
    Sorry, maybe if the glute control comes out and includes maybe some equal morphs like the third party morphs I need right now, maybe then I will go to fix all my poses.
    edited April 2016
    that I have done smiley and maybe I can use some of the morphs for manually use. The problem I have is that I need some third party morphs but in combination with your product I get some unwanted results (not really bad results but not perfect enough for me sad maybe I am a bit to petty-minded)
  • RGcincyRGcincy Posts: 2,864
    Zev0 said:
    ... for now my focus is on Aging Morphs 3
    Yeah! Everytime I use Genesis 3, I miss having these available.
    edited April 2016
    Okay, well the automatic leg bend control I can use without any problems except for one pose, for this pose I have to find a way because I need some sitting morphs of the really great working "buttocks work" product and these two morphs get not in conflict (means a bad result or so) with the bend control but have not the wanted and needed result at the end. BTW other morphs of the "buttocks work" product work really well in combination with bend control but these two sitting morphs especially one of them that makes a real flat but widen bum but (sitting pose) works a bit contrarily to the leg bend control.
  • tl155180tl155180 Posts: 994
    Excellent work on this Zev0, as usual - but really even better than I was expecting (I was anticipating needing another morph set from somewhere else to complete the look I needed, but Bend Control is so good that it won't be necessary anymore). Bought it as soon as it came out. Thanks!
    Now just counting down the days to Glute Control 3 wink. Wallet on standby!
    Thanks for the kind words. Glad you like it. If all goes to plan Glute Control will be out this week hopefully. Owners of Bend Control will get an added discount. Well thats the plan.
  • This week would be great. Trying to hold on my store credit for some more days ;-) And looking foward to any discount for owners of those other control packs. They should really think about offering some kind of PA subscription. I would definitely subscribe.
    Sigh...Looks like there is no space for Glute Control this month. Pushing for early next month.
    edited April 2016
    We'll still be here! It's pretty much right around the corner Anyways! ;^) Thanks again for the hard work!
    I hate to say it, but that's probably a good thing. My CC could use a break of a week or two after the last two months.
  • Josh P.Josh P. Posts: 49
    Out of curiosity, what's this "Tween Julie 7" that I've seen in morph compatibility lists?
