how to render with transparent background
GuptatsgGuptatsg Posts: 52
is there any procedure to achieve transparent background while rendering,
which format should I save, JPEG or TIFF or any other format.
( After rendering, i want to use the rendered image in Photo shop for background effects)
Thanks in advance
  • Richard HaseltineRichard Haseltine Posts: 108,626
    PNG and TIFF will give you transparency or an alpha channel, for areas that don't have any geometry.
  • SzarkSzark Posts: 10,634
    this should help http://www.daz3d.com/forums/discussion/8207/#108606
    all I will add the above link only works with no background plane or prop in the scene that covers the entrie background
  • GuptatsgGuptatsg Posts: 52
    Thank you for your replies
  • Bruno AcciolyBruno Accioly Posts: 22
    If you plan to use your transparent background stills on Final Cut Pro X I would even consider watching this video so you can change duration of the stills so it can match the frame rate you want.
    Final Cut X Image Sequences (duration)
  • I want to update this thread because in cases you use a lighting HDRI from the store... the best solution is just go to Render Settings... in Environment, select Dome and on the right panel choose Draw Dome "OFF".
    Done.
  • RuneRune Posts: 5
    Done.
    Thanks! That's actually pretty handy in 2022. I tried that and still having an all white background but I'll look at other Environment Settings.
