Greedy girl for G3F (Ropes for G3F) how can i fit with other G3F bodymorphs?
kayto93_073094d40c
in New Users
Hi everyone,
how can I fit the rope prop (https://www.renderosity.com/mod/bcs/the-rope-for-g3f/111265) to g3f.
The attach fils will show what i mean:
1. G3F normal body (with the greedy girl morp witch only change the chest area)
2. G3F with Teen Josie body morph (she is to thin and the ropes doesnt fit anymore)
3. Try to: Edit -> Object -> Rigging -> Convert to figure (which option i used is unimportant. Alle the same result)
I hope someone know a other way cause I dont know how.
I take it the rope is a prop rather than a figure? To get auto morph transfer you would need to make it a fitted figure for Genesis 3 female - that woudl be done using the Transfer Utility, with the rope set as the target and Genesis 3 Female as the Source; assuming it fits the default figure there should be no need to change any other settings. Alternatively use a modeller (or DForms) to make a fit morph for each shape you wish to use it with, which would probably allow better results but would require a lot more work.
