Question about Product textures
I am looking at this environment and am curious about how it will look when I get it.
https://www.daz3d.com/franklin-square-loft
It says in the desciption that textures are available in the Product Library. Does that mean to search the Daz Store? I tried that and didn't find anything associated with this particular environment. I don't want to buy it and have everything just be bleach white with no textures for it.
If anyone can shed some light on this, I'd appreciate it.
Thanks! :)
    It says that texture templates are available in your product library (it means your product library that you can see in your DAZ web account. If you click on a product there you will see templates for download, if available, under the product download links themselves). These are UV templates for people who wish to create their own custom textures for the model. This is entirely optional.
    The actual textures created by the artist will be pre-applied*, so when you load the model from Studio the textures will be there.
    * This is usually the case. Sometimes the model is textureless when loaded and you apply the textures from the materials folder in Content Library or Smart Content. This is often when there are a lot of material options, such as with hair. In either case the textures will be provided.
  • DDCreateDDCreate Posts: 1,419
    Hiro,
    Thank you so much, I understand now. I'm still a little new with a lot of this stuff so I just didn't want to rush into buying something and bite off more than I could chew. I apprecaite your explaination.
