mcjAutoLimb2015 - A Kind of IK System - G3 and G8 Workability Confirmed
2
  • mCasual said:
    maybe i broke Gen2 compatibility when i introduced Gen3 compatibility
    but nah, i recently used it on Aiko5 ... she's Genesis 2 i think
    i never really ascertained if my Gen2 figures were automatically converted to Gen3 when i installed Gen3 and/or Daz Studio 4.9
    so lets verify this
    -1 load a Genesis 2 figure
    My DAZ 3D Library\People\Genesis 2 Female
    she doesnt have Aiko5 morphs, just Victoria 6
    - 2 - i select her index finger [3]
    3 - i start mcjAutoLimb2015
    4 - i exit mcjAutoLimb2015
    this created a target node at the location of her index finger[3]
    and a 'pole vector' which indicates how the arm is twisted
    - 5 - i move the target node near A3's face
    - 6 - i select the target node, followed by the index finger[3] node
    - 7 - i use mcjAutoLimb2015 for the current frame
    it works !
    then using null nodes positioned on the "palm" of their finger tips as the 'targeters' you can do precision posing
    I'm trying to use this with a Gen 2 figure, but I can't seem to get it to work at all. Does this only work for Gen3? Should I be using an older version for Gen 2 figures?
    aiko 5 is a genesis 1 figure. aiko 6 is genesis 2.
  • RuphussRuphuss Posts: 2,631
    thank you for explanation casual
    if i lock the side rotation of the thigh/shin
    will it be overwritten ?
  • FrankTheTankFrankTheTank Posts: 1,499
    Thanks for the followup testing, I'll give it another shot. Unfortunately, I can't work on my computer right now because its rendering for the next 12 hours. But i'll try again tomorrow.
  • mCasualmCasual Posts: 4,607
    only the shin's 'bend' control gets tweaked by the script, the twist and side side are free to do what they want
    in most cases, the script will not be prevented from achieving it's goal ( the proper leg-length ) due to this
    for the thigh, if the side-side control is locked, the script wont be able to "point" the leg at the target
    when the figure ( ex: Aiko3 ) has a buttock joint, you can animate it to help the script reach its target
  • takezo_3001takezo_3001 Posts: 2,026
    Why daz abandoned it's IK is infuriating, thanks for your D|S augments!
  • fabian_2897766fabian_2897766 Posts: 6
    edited September 2016
    Hi McCasual,
    I'm totally new to daz studio, actually i come from Poser and wanted to give a try to daz for animating humanoids.
    I was nearly abandoning it watching how poor was the rig and the fact there was no real IK system.
    I just found this post, downloaded your script install it (I'm on mac) but i can't really figure how it works :-/ I really want to make something similar to your animation.
    http://orig10.deviantart.net/c3e8/f/2015/332/f/5/mcjautolimb2015_a_sort_of_ik_system_for_daz_studio_by_mcasual-d9ia7vw.gif
    Could you please explain me a step by step guide to make it ?
    I load genesis 3, select the toe, apply your script, it seems a target goal is created but then if i move the hip or the pelvis of the character the toe does not stay at the right place. Am I doing something wrong ? I tried with the bone tool and the simple translate tool. No luck.
    This sounds as the only alternative to start animating things right here in daz, so i better need to understand how it works :-) Thx in advance!
    Post edited by fabian_2897766 on
    Reposting a long answer i gave someone
    Hello
    This animation
    was one of the test animations i made for the release of mcjAutolimb2015, which was the first version to support Genesis3
    note that you increase chances of success by using older Poser figures  ( ex: victoria 3, 4 )
    On the forum thread for AutoLimb2015 i answered some questions and gave a step by step example
    http://www.daz3d.com/forums/discussion/66717/mcjautolimb2015-a-kind-of-ik-system-now-genesis-3-compatible/p1
    The official release page for mcjAutolimb 2015 is the manual
    https://sites.google.com/site/mcasualsdazscripts6/mcjautolimb2015
    it's my web site, it's a very safe web site, i dont think there's many ads and pop ups if at all for visitors.
    Also see previous versions of the script which may have less features, but are similar
    https://sites.google.com/site/mcasualsdazscripts3/mcjautolimb2014
    http://www.daz3d.com/forums/discussion/43130/mcjautolimb-2014-an-ik-system-for-animators-now-with-poles-for-ds-1-2-3-4
    https://sites.google.com/site/mcasualsdazscripts/mcjautolimb
    There's a tutorial here for a swingset animation
    https://sites.google.com/site/mcasualsdazscripts3/swing-animation-tutorial
    There's a tutorial here for cycling
    https://sites.google.com/site/mcasualsdazscripts5/tutorial-pedaling-with-mcjautolimb2014
    Generally speaking, as is explained in the manual, this is not a "Live" IK system like poser.
    if you select a figure's left foot and run the script
    the script creates a target node and a 'pole'
    the only thing you can accomplish now it so get mcjAutoLimb to calculate the left leg pose
    that will keep the position of the foot in space fixed for the duration of the timeline's play-range or animation range
    if you select a figure's left foot and run the script and immediately exit the script
    you could animate the position of the target node
    then if you select the target node, followed by the foot and run the script
    what you can accomplish is to get mcjAutoLimb to calculate the left leg pose
    that will make the foot follow the the position of the target node for the duration of the timeline's play-range or animation range
    Usually, there's a second phase where you use mcjKeepOrient or mcjHoldOn to  take care of the foot orientation
    So this is different from IK, but i find it more practical for my way of animating
    if you read the links i posted above you'll improve chances of obtaining millimeter-precise animations
    ( ex: in the case of Genesis3 mostly, turning limits Off of the thigh or shouldr joints can make a big difference, also, unparenting the 'poles' can solve issues
    Note that Daz studio does have a type of IK system called pins
    Post edited by mCasual on
  • mcasual does a pretty good job with regards to scripts. They can be quite useful for my animation projects.
    The AutoLimb script is very promising to me with regards to certain 1950s dance animations I asked about in another thread in the Product Suggestions forum quite some time ago.
  • EightiesIsEnoughEightiesIsEnough Posts: 1,235
    edited November 2018
    I am wondering if there is a script that can allow for the raising of the heels with the toes planted firmly to the surface and legs straight, and if there isn't, maybe that's something that can be considered for development.
    Post edited by EightiesIsEnough on
    mcjautolimb2015 does include the ability to set the toes as the object that must not move
    in conjunction with mcjKeepOrient
  • PsyckosamaPsyckosama Posts: 508
    Can this work with Genesis 8?
    yes it does i'll post a 30 frames gif showing the result
  • rames44rames44 Posts: 336
    Works perfectly with G8 - I’m using it extensively.
    Genesis 8 test done today
    edited November 2019
    Update Update Update
    1
    i added a button that does what mcjKeepOrient does
    meaning, you select a foot, run mcjAutoLimb2015 v110619
    and the location and the orientation of the foot will be maintained
    for more complex tasks you will still need to use the standalone mcjHoldOn script
    2
    I added a button to graciously unparent the pole-node
    because i never seem to be able to figure how to unparent it without having it lose its orientation
    948 x 518 - 70K
  • Nice update, very useful. Thank you for your hard work.
  • IvyIvy Posts: 7,165
    Thank you Jacques for the update , you rock  :)
  • Thank you so much! You go above and beyond each time. I am starting to believe that Daz is never going to come up with a working full IK system. Without your scripts, I would've probably given up using Daz a long time ago. Having the autolimb and orient in the same tab surely saves a lot of time. I also like that you can undo all the frames the script creates with a single click. Keep up the good work
  • Is there any explanatory video to use this tool?
    there's a tutorials section in the index, one of them shows how to use it for bicycling animation and i think another one for swingsets
  • yagakisanyagakisan Posts: 65
    edited October 2020
    Hello,
    I'm trying to use this script but I can't figure out how to do it properly...
    I have two figures, the first has her left hand on the shoulder of the second (Right Collar), what I need is to keep her hand on the shoulder while the second figure moves his torso back (and consequently she also moves her torso forward).
    Sorry but I don't understand how to do it!
    I select the (G8M) RightCollar, then hold CTRL to select the "targeter" (G8F) LeftHand, I run the script with the default settings (all the 30 frames) and press Do It; The left arm changes the pose pointing at the G8M hip level.
    So I tried creating a Null Node, parented to the RightCollar and moved in the same position, but nothing changes.
    Another question, I didn't understand if I need to run the script at the first frame, BEFORE completing all the other keyframes of my animation, or at the end (but I don't get if then I should anyway pose my characters hands...).
    Please help me, it would save me a lot of time!
    Thanks
    Post edited by yagakisan on
  • yagakisan said:
    Hello,
    Thanks
    You need to select the null first and then the hand that you want to keep in place. Selecting them in that order is important. Don't select anything else and make sure that the null is patented to the right collar. Run the script at the beginning of the frame. Most of the times this works immediately, but sometimes you'd also need to set or remove joints limits depending on the direction of the movement.
  • RobinsonRobinson Posts: 751
    This is for hands and feet.  It would be nice if you could use other parts of the limbs, shin, forearm, for example, i.e. that's the one you want to stabilise (adjusting thigh and/or upper arm and shoulder).
    Still, very useful regardless.
    i also wrote mcjoptimalposea
    https://sites.google.com/site/mcasualsdazscripts7/mcjoptimalposea
    joint by joint it tries to make, for example the shin reach the position of something else, for example a null node
    so if you use mcjMakeTarget and create a target (null node) at frame 0 of an animation
    then mcjoptimalposea can help you keep the shin at its initial location
    https://sites.google.com/site/mcasualsdazscripts/mcjmaketarget
    there's also mcjKeepOrient which can make the shin orientation in space remain constant,
    but that's a special tricky case since the shin is not supposed to have the side-side joint used
    for the head and thighs and shldrs mcjKeepOrient works fine
    https://sites.google.com/site/mcasualsdazscripts/mcjkeeporient
    unrelated animation, well it's related because i used mcjAutoLimb2015 and mcjMakeTarget and mcjCycleFilter mainly
    Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm.
    I'm going to give mcjoptimalposea a go (btw, I don't mind a little shin side-to-side, although it does make my eyes water).
    Honestly mC, I don't understand the instructions.  I think that script was made for someone with a brain.
  • I have no trouble with any scripts so far except mjcHoldOn.
    in the tutorial, do I use it by it self or do I use mcjMakeTarget-mcjAutoLimb first and then mjcHoldOn?
    Also, should the whole arm move or just the hands on Aiko3? I have gotten it to work somewhat but the Aiko 4 moves but only the hands move on Aiko 3.
    Other than that all other scripts have made me stop using poser almost all together.
    edited November 2020
    mcjHodlOn simply maintains the orientation of the hand ... relative to what's being held
    lets say you want Amy's right hand to hold-on William's left shoulder
    at frame zero, you position Amy's right hand so that it grabs William's left shoulder
    you select Amy's right hand ( the joint is near her wrist ) and you use mcjMakeTarget to make a null node at the position of her hand (wrist )
    then, you select the null node , which has a name like rhand_target click the keyframe button because it's sometimes needed for the next step
    then you parent that target node to William's shoulder
    so, from frame 0 to 30 as William moves, the target for Amy's hand will follow the shoulder
    then you select the target node, followed by Amy's hand, and use mcjAutolimb
    this takes care of the hand position
    but chances are the orientation of the hand is now all wrong
    so, at frame 0 ( where she has the perfect grip )
    you select Amy's Hand followed by William's shoulder ( in that order while pressing the CTRL button on a PC )
    and use mchHoldOn to fix the hand orientation for frames 1 to 30
    just now i did this but for a pumpkin instead of a shoulder, i had to make 1 target node for each hand and use mcjAutolimb and mcjHoldOn twice
  • minnow3dminnow3d Posts: 4
    mCasual said:
    mCasual said:
    Post edited by minnow3d on
