Thread to discuss/collect tips, tricks, tutorials, etc. for Mec4d's PBS shaders (all volumes)
greymouser69greymouser69 Posts: 501
edited May 2016 in Daz Studio Discussion
These shaders are so amazing but it can be very time consuming to dig through numerous threads to understand how to best use them plus the countless little tips & tricks so I decided to create a central thread in what I hope is the best place to collect them.  I'll try to copy/paste what I can find from various other threads as I can.
Lets go folks and share our understandings!
Collection of related threads so far:
https://www.daz3d.com/forums/discussion/76602/mec4d-pbs-pure-metals-merchant-resource-commercial
http://www.daz3d.com/forums/discussion/72523/mec4d-pbs-shaders-vol-2-released-commercial
https://www.daz3d.com/forums/discussion/76602/mec4d-pbs-shaders-for-iray-vol-3-merchant-resource-commercial
Post edited by greymouser69 on
  • MEC4D said:
    With the moss shader, I see that the scale is huge , it is a moss shader for so huge area you need to tile it down and also try to reduce the normal map level to lower , you should not need any extra geo shell on top unless it is deformed to show rocks bellow, I used the moss on huge areas without issues on Stonemason set .  Ivy shader images can be rotated under Layered Image Editor you can turn it 90-180 degree so it grow up or side or down , use geo shell and offset it a little bit , make sure you rotate all maps in the shader including cut opacity
    There is just one CTRL+ what is the grass shader that can be used on trees and grass where you have already textures plug in , other shaders need all the maps to working correctly so no CTR+
    I don''t use any bumps just normal and when you use CTRL+ you changing the settings of the old shader and not load any new maps it not working this way and even if this worked for the breaks it was a pure luck
    all shaders beside the translucent green one can''t be used with CTRL+ so if you want a wall just select the surface and click on the shader and scale it proper in proportions
    if you want to get the green darker just change the base color to desire green and the same color use under Translucent Color
    and you don;t bother me at all , nice you ask question and learn your ways out so letter you are better in your creations ! and know how to use shaders for the future
    A beginning
  • MEC4D said:
    TIP when I apply the shaders I always switch to other camera and zoom to the surface to make sure the scaling are correct for the proper shading  and reflections for best result
    My favorite one is the metal combination and the middle .. also when you render render on letters or hard surface models make sure the angles are set too lower especially for metals as Smooth angle on hard edge models will make wrong reflections  for example swords, machines , tables and any surface that suppose to be flat
    MEC4D said:
    TIP when you use the leather shader on clothing that have own normal maps, you can load the clothing normal under the Normal map channel and the leather normal from the shader under the Top Coat Normal channel  and left the rest unchanged beside scaling  , now you can scale your maps individually  via image editor in DS so the original normal map from the clothing is not tiled and only the maps from the shader ..
  • Another one from Mec4d:
    TIP leather and skin love to have some slightly light source behind on the side it bring out the texture and normal even better and make it more dimensional thanks to fresnel , sometimes just white object on the side that is not visible to the camera can reflect the light back from the side especially if you render just with sky-sun or scene without much elements in , try it out next time
  • L'AdairL'Adair Posts: 9,479
    Thank you for starting this topic, Greymouser. I've favorited the thread! heart
    With so much to learn already, with only two volumes out, it is a great idea to keep the tips and tutorials in one place. I'll probably mostly lurk, looking for answers, but I'll be here.
  • VhardamisVhardamis Posts: 576
    Another Mech tip on Fabric shaders:
    (example here was a cloth sail)
    TIP ...How to replace the fabric shader with original textures , Apply the white cotton ,  then load the original Sails color textures under Base color and under Translucent color and leave everything else as it is and you should have it all perfect you want with the original textures, you can use also the original Sails normal or  bump  maps no problem it will not affect the result
    Fantastic resource! thanks for starting this!
    edited April 2016
    Uhhhmm where is the little favorite star thingy?  Its not showing for me....Never mind i refreshed and now its there.
  • MEC4DMEC4D Posts: 5,249
    I will contribute more to it once I am done with my projects here , very good idea @greymouser69
  • I recently bought the two volumes and I started using them immediately (I was having trouble with some fingernails, for example, so I used one of the presets and it solved my problem—once I'd sorted the tiling out!), but I definitely feel I'm only scratching the surface of them so this will be a very useful thread. Thanks for starting it.
  • Ok I think I am starting to get an idea of the whole scale thing.  As Cath said you really have to "eyeball" each surface because I've had a surface that needed scaled down and others that needed scaled up to look appropriate.
    That is correct depends of the UV's one part can be need to be scaled up or  down,  especially with  overlapped UV's were the same scale dont count ', or your plane ground is bigger so you need to tile the materials with higher volumes , I included couple of the Scale Tools as references for fast checking what you need in the scale or better say Tilling value , higher values smaller details, lower values bigger details of the shader
    usually everything in the scene that is bigger than 20 inches need to be Tilled up and smaller than 20 inches down
    Scale up = Tilling Down the shader - bigger details on  the texture
    Scale down = Tilling Up the shader - smaller details on the texture
  • Oso3DOso3D Posts: 15,112
    By the way, if the uv mapping of your object is annoying or distorted, consider using a decal over the entire item.
  • greymouser69greymouser69 Posts: 501
    edited April 2016
    Not yet complete but shows some nice details on the brick.  I may need to scale up the concrete on the floor, not sure. Forum distorts it, full size looks a lot better.
    Mod edit to fix your image
    1440 x 810 - 3M
    Post edited by Chohole on
    Very well done , I would tile down the value of concrete just slightly for bigger details , the breaks looks really great and very physical appearance I see shadows under each break
    if you want in the future get the break another look you can change the Base white color to little darker but never go below 186 for more smoky older effect and the same to other materials they will look less new .
  • Thanks for the tip, I will give that a try.  One thing I was kind of wondering how to do would be to dirty it up some since it is a garage where they work on vehicles so it shouldn't be quite so clean.  Dirt & oil spots maybe?
    yes you can try on Decals over it , and set the cut opacity little lower for the semi-transparent dirt effect and change the white color under maps for little more gray it will give the less new effect , also try to play with the light , make one lamp in the back less bright for more uneven dramatic effect . it will create more depth to the full scene , also blacks under the tone mapping will add some drama to the scene creating more contrast usually I use at 64 value
  • Ok, adjusted some more.  Reduced the lights from 120 watt fluorescent to 85 watt fluorescents, scaled up the concrete floor and darkened the diffuse on both floor and wall maybe a bit too much on floor...  Adjusted crush blacks in tone mapping to 0.64 as well.  Still in progress but I am getting somewhere.  Interestingly the reduced lights and maybe crush blacks actually made it render a lot quicker than the previous settings.
    1440 x 810 - 2M
    Yes it starting to look more regular indoor and less like light in super market more atmospheric now
  • Thanks Cath!  I'm completely new to Iray since I was away from DS & 3d for about 3 years and just came back this year.  Lots of new things to learn!
    I thought I saw you say somewhere that it was possible to use multiple different of these shaders on the same surface but never saw you explain.  Or am I just mistaken?
  • Nice little video tutorial about rendering glass from Cath.
    https://www.youtube.com/watch?v=WV7PVNj8mIQ
    edited April 2016
    I was about to post it here haha  , Thanks!
    Post edited by MEC4D on
    Here is a tip how to use Matte object in Daz Studio for masking and composing figures into 2D not really my shader related but very useful
    you can use Matte objects to hide figure parts, as shadow catcher or light or reflection catcher
    here mini-tutor about using matte to hide partial models to match 2D backdrop or HDR
    Here is another tip about using Matte function objects in Daz Studio , this time Shadow Catcher , cast shadow on 2D backplate or HDRI walls etc..
    Here one more tip of using Matte Object to hide your 3D figure behind 2D object in 2D backplate or HDRI
  • JerifeJerife Posts: 272
    Excellent thread greymouser. Thanks
  • ErdehelErdehel Posts: 387
    When tiling with high values and/or tiny sized textures beware of the pattern that will appear unless it is what you really want (chainmail for example). In this picture and the previous one you can see a pattern forming on the concrete wall. It is quite obvious between the blue toolbox and the shelves.
  • Great thread! I think I have read through most of the ones I could find. I missed out on some neat freebies with getting too busy, but I am learning a lot. :)
