Real Fur
H. J. ValdiH. J. Valdi Posts: 98
Hi
I wanted to ask if anyone has Real Fur for the Millennium Big Cat, and whether it is worth buying. $18 is a lot to spend on something that may not be leaps and bounds (not a big cat pun, honest) beyond the standard fur that comes with the Millennium Big Cat.
I was hoping that it would turn up in the PA sale, but that's looking more unlikely as the days pass. Still, I won't be buying it until the PA sale ends, just in case.
Anyone able to give some feedback on it, please?
Thanks muchly :-)
  • carrie58carrie58 Posts: 4,175
    I don't have it but did you notice it's for Carra,not DS.Me I'm waiting for Alessandro's LAMH product which will allow us to put hair on pretty much whatever you want .........
  • Knight22179Knight22179 Posts: 1,195
    Hi
    Thanks muchly :-)
    Despite what Carrie said, it IS compatible with DS and Poser. From the promo renders, I'd say it's worth the price. However, for a few bucks cheaper, I'd get this instead. http://www.daz3d.com/shop/lions-by-am
  • H. J. ValdiH. J. Valdi Posts: 98
    It does state that it requires Carrara 8 Pro, but in Compatible 3D Software it lists Daz Studio, Poser, Carrara. So I'm assuming that means it can be used in Daz, and that if you're going to use it in Carrara you need at least Carrara 8 Pro
    Thanks Knight22179, but I'd rather get the Real Fur as it has fur for various Big Cats.
    Your welcome and ok. ;)
  • fixmypcmikefixmypcmike Posts: 19,726
    The compatible software list is incorrect, it only works in Carrara. I've flagged it for DAZ 3D to correct.
    Really? Oh bugger! >:-(
    Lucky I decided to ask before buying it then. Thanks, fixmypcmike! :-)
  • JOdelJOdel Posts: 6,322
    And it's old enough that it ought to work in earlier versions of the program, unless it's been given an update that makes that impossible.
  • TaozTaoz Posts: 10,356
    Well in case you don't know you can return anything you buy within 30 days and get your money back, or a store credit, so ther'e no harm done trying out things you're not sure about.
