Can someone explain the camera functions?
UpiriumUpirium Posts: 730
edited December 1969 in Poser Discussion
For PP2012? I know some of them but I'm confused on most of them. Like shutter open, close, hither, yon, etc
  • AscaniaAscania Posts: 1,856
    Are you somehow averse to reading the manual?
  • hal1hal1 Posts: 0
    Focal is obvious - it is the same thing as the focal of a real camera. I use value from 28 (wide angle) to 80 (telephoto)
    focus distance and f-stop are related to Depth of Field : focus distance correspond to the focal position and f-stop is your camera aperture (The larger the number, the smaller the aperture opening, the lesser depth of field effect)
    shutter open/close is related to your camera speed and is only used if you make an animation with motion blur activated
    Hitter and yon control the cliping plane position for the preview : hither is the minimum distance where the object are seen in the camera windows there as yon is the maximum distance. None of them have an impact on render.
    Hope this help you :)
  • WandWWandW Posts: 2,910
    edited June 2012
    Post edited by WandW on
