DIM error with The Slinger?
SimonJM
I suspect it's not just me, but finally been able to get round to installing The Slinger (A MortemVetus item from RDNA) but it fails to install with the follwoign being in the log:
Product failed check, moving to next product : IM00027878-01_TheSlinger.zip
Post edited by SimonJM on
That sounds like a bad zip, try deleting it (which you can do from the right-click menu in DIM) and redownload.
I have, same result
Same here
I downloaded this without problem two days ago, but I notice there is an update in DIM dated yesterday - maybe this is faulty?
Annoyingly I got the original download but never got round to installing it! ;)
the "Nibbler" product has a corrupt .zip as well. i wonder if it's a delivery server or hdd problem?
"The Duke" is the same too - it's only a small .zip so I tested the DIM download and the Product Library one (just in case it made a difference) but they're both bad. Tried to unzip manually and got this:
Add "Balverk" to the list, get an error when I try to manually install on the gen file too. I have submitted a ticket for it
We've reported this.
Add Betty to the list.
We've just been told that this is being worked on and should be fixed tonight.
It worked on the Slinger this morning (CDT USA). Downloaded and installed with no problem.
Much better, thank you!
