DIM error with The Slinger?
SimonJMSimonJM Posts: 6,104
I suspect it's not just me, but finally been able to get round to installing The Slinger (A MortemVetus item from RDNA) but it fails to install with the follwoign being in the log:
Product failed check, moving to next product : IM00027878-01_TheSlinger.zip
Post edited by SimonJM on
  • Richard HaseltineRichard Haseltine Posts: 111,923
    That sounds like a bad zip, try deleting it (which you can do from the right-click menu in DIM) and redownload.
  • SimonJMSimonJM Posts: 6,104
    I have, same result
  • fastbike1fastbike1 Posts: 4,084
    Same here
  • MelanieLMelanieL Posts: 7,885
    I downloaded this without problem two days ago, but I notice there is an update in DIM dated yesterday - maybe this is faulty?
    Annoyingly I got the original download but never got round to installing it! ;)
  • the "Nibbler" product has a corrupt .zip as well. i wonder if it's a delivery server or hdd problem?
    edited March 2016
    "The Duke" is the same too - it's only a small .zip so I tested the DIM download and the Product Library one (just in case it made a difference) but they're both bad. Tried to unzip manually and got this:
    Post edited by MelanieL on
  • 3Ddreamer3Ddreamer Posts: 1,357
    Add "Balverk" to the list, get an error when I try to manually install on the gen file too. I have submitted a ticket for it
    We've reported this.
  • winmathwinmath Posts: 149
    edited March 2016
    Add Betty to the list.
    Post edited by winmath on
    We've just been told that this is being worked on and should be fixed tonight.
    It worked on the Slinger this morning (CDT USA). Downloaded and installed with no problem.
    Much better, thank you!
