Renewing platinum - order problem
Hera
in The Commons
Hello!
Do I have to order the renewal of the platinum club separately to get the platinum discounts on for instance Isabella and the Mortem Vertus items?
If I add the PC renewal at the same time as the rest of the shoppings, I don't get the PC discounts on the products in the order. Thus I have no idea what for instance the Isabella pro bundle will really cost me. Is there somewhere I can see the PC discount before I renew, so I can make some decent calculations?
I also have http://www.daz3d.com/armory-rock-stairs in my cart, which is suposed to come with a discount as 41% if I stack it with Isabella pro bundle, but it doesn't seem to work, the price still shows with only a 30% discount.
Yes, because the system needs to know that you are a PC+ member before it can start applying the PC discounts.
PC discount is only for DAZ Originals, and is 30% unless there's a special promotion going on (there was one last week-end, we got 45% instead of 30%). You would get the discount on Izabella but not Mortem Vetus items, which are PA items.
From memory when you go to your cart you should see a "Platinum club would make you save $XXX" message if you're not a PC member.
