Aslan Court 3 broken after Connect update?
SnowSultan
in The Commons
I recently updated Aslan Court 3 through DAZ Connect and now it doesn't load properly (the main walls are bounding boxes, meaning the geometry is missing or referenced incorrectly if I'm not mistaken). Could someone else confirm this? Thanks in advance.
I don't have that one, but the same thing happened to Aslan Court 1. http://www.daz3d.com/forums/discussion/comment/1018123/#Comment_1018123
Thanks for that link, they suggested just installing it again with DIM and that did fix the problem (sort of, the copy I need updated in my scene file was not fixed).
Yea, the set was updated.. which causes the issue you mentioned. The problem was there was a little light leak which you'd never see in 3DL, however Iray shows up all the gaps so I'm having to release fixes as I go. Not ideal, but it has to be right!
To clarify - the new version works ok.. yea? If you want to replace a broken version in your own scene, just delete it and reload the new fixed one.. then resave the scene.
Thanks for stopping by Jack. :) Yes, the new one installed through DIM does work (not through Connect though, I did try uninstalling and reinstalling that version too).
As for replacing the one in my scene, that was slightly more difficult because I had angled and hidden parts of mine, but a simple copy/paste from the original did speed things up slightly.
Thanks again!
