Show Us Your Iray Renders. Part V
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Nother http://fav.me/d9vf7oi
I use http://www.daz3d.com/uht-hair-shaders-for-iray a LOT. Like nearly all hairs, when I use Iray.
It occurred to me that when using bump... it would be nice to also have Normals. I wonder if it would improve things?
So I fed the UHT bump map through http://cpetry.github.io/NormalMap-Online/ and gave it a whirl, and I think it does improve things.
It looks like it might bring the highlights out a little more. UHT is one of those things on my wishlist, but I haven't gotten yet. Will have to test this out once I get it. That looks like an interesting link to the normal map thing. I usually do my normal maps in Gimp or FF, if I'm using that for a texture. I'll have to try using this in the future. Thanks for the link.
I have FF, GIMP, and now Photoshop, so they can all do Normal mapping. Not sure why I still use the browser thing, but hey. ;)
And yeah, the thing that hit me was that the point of Normals is to reflect the play of light at angles to the viewer, rather than bump. Previously I was swapping the bump map into displacement, but that frankly stinks in Iray (although, interestingly, I think UHT would work pretty well in 3DL!).
I think just having Bump and not Normal ends up leaving the hair looking a little flat.
Thankfully, it's a VERY easy thing to add. (I just plopped the normals in the same directory as the other UHT stuff and it takes me an extra second or two to add)
My latest attempt - learning GIMP through using Ron's Brushes for smoke and flame.
All in a Day's Work
After a long day at the office, sometimes it's nice to just stop, take a deep breath, and contemplate the joys of job well done....
For Mec4D's contest thingie, and trying out Photoshop for the first time, seriously, in years.
(For the distance effect; distance canvas masked very nicely)
http://willbear.deviantart.com/art/Fearing-Green-597406154
Which Mec4D's contest thingie?
http://www.daz3d.com/forums/discussion/72523/mec4d-pbr-shaders-vol-2-w-i-p-commercial/p11
Though I think it's too late to pick up the free shaders for it.
It looks like the link is still active so grab them while you can!
edit: then enter the contest and show Mec4D how much you appreciate her shaders!
Here's another example of the power of reshading. This is Greek Baths, which came out in 2004. That's a 12 year old set... useless and ancient, huh? Nooot quite.
A combination of Marble, ceramic pack, Mec4d pack, and my WTP ocean ripples shader for the water.
Reminds my that I have a typical UK street and an Arab house in my cart & meant to look at other place models today...I have practically nowhere to make intersting scenes.
REALLY liking Photoshop's tone mapping -- making it so much easier to deal with bright skies without blow out.
One of the things i really appreciate about Iray worlds is that its real texture maps..i been expermenting with changing the shaders for the ground as well as tile sizes etc.
Daniel
I really like cars. This one's (supposed to be) an Audi R8:
That car looks cool, cjmarsh!
I'm playing around with settings to give it a bit of a toon look to the genesis 2 figure...
Really happy about Photoshop some more. This image was proving really hard to do in just 8 bit. But with good tone mapping to carefully balance the sky and ground, it balances very nicely.
Using HRDI BG speeds things up significantly http://fav.me/d9vpg2a
Like the invisible jet off to the side there....
I keep forgetting how useful 'second skins' can be. Here's a couple of Vyktohria's recent ones applied to geoshells and recoloured.
Thanks just used the uber glass shader on a plane prop. Diorama http://fav.me/d9vqnnv
Another one, Mercedes SLR:
Nice work. I'll have to move that suit up to the top of my wishlist, as I'm failing miserably with the dynamic clothing.
I love dynamic clothing, but it's a HUGE amount of work to get it to play right, and that takes up enormous time you could be doing other stuff.
The headlights don't look quite right...and I'm not sure if it is a setting or a modelling problem, but there is something a bit 'off' about them.
I think they need headlight covers, they look missing.
Or they are perfectly flat...I looked up some lights for it and all the ones I saw had a curve to the cover/lens.
Yeah, there actually wasn't any lenses on the model at all so I was trying to fake it a bit with reflections. Not a lot of angles without something that jumped out at me as fake, this one included, but at least the bright metal hides the missing pieces a little.
Boy, this project was a pain. Heh. Had to rerender a bunch of times to get the effects I want. Four images of same scene at different zoom (more or less).
http://willbear.deviantart.com/art/Marble-male-nude-1-1-597730628 (warning, nudity)
http://willbear.deviantart.com/art/Marble-male-nude-1-2-597730708 (warning, nudity)
http://willbear.deviantart.com/art/Marble-male-nude-1-3-597730758
http://willbear.deviantart.com/art/Marble-male-nude-1-4-597730812
The water in this uses my WTP Ocean Ripple shader on a cube, then an Iray decal with the same and also a ripple Normal map plopped on top (decal set to project from above).
At first I was disappointed that Iray decals don't do Displacement, but I've really started to appreciate the value of Bump/Normal maps. ALSO really starting to appreciate the way bump and normal maps can be combined in different ways -- my WTP shaders have procedural bump options but not procedural normals, but you can just add a regular normal.
I really like that water texture, nicely done. The normals really do work well too, although I think there's a few too many ripples on the big ones.
I may or may not have found a free car model site...
Ford Mustang GT Eleanor
