ISO: Helicarrier-like Vessel
MJ007MJ007 Posts: 1,718
Hello all,
Is anyone aware of any type of transport that could be passed off for a "modern day" Helicarrier-like vessel?
Any and all suggestions are welcomed.
-MJ
  • Charlie JudgeCharlie Judge Posts: 13,613
    edited March 2015
    There doesn't seem to be too much available but I located this from another thread:
    https://3dwarehouse.sketchup.com/model.html?redirect=1&mid=ba027bc277c1ca45fab6379424355170&prevstart=0
    You will have to use sketchup or some other program to convert it to obj or fbx
    Reference to the other thread:. See post 181:
    http://www.daz3d.com/forums/discussion/9443/P180/#548839
    Charlie
    Post edited by Charlie Judge on
  • MJ007MJ007 Posts: 1,718
    Sorry... I forgot to mention I need something for commercial usage.
    -MJ
    edited March 2015
    I doubt if you can come close to the 'Helicarrier' without pushing copyrights but maybe look at 'Aircraft Needle'
    http://www.daz3d.com/aircraft-needle
    Also checkout Kibarreto's store:
    http://www.daz3d.com/kibarreto
    And Petipet's store:
    http://www.daz3d.com/petipet
    Charlie
  • erik leemanerik leeman Posts: 262
    Since it already is a mesh model you might be able to use this one from GrabCAD:
    aircraft carrier (3dsMax)
    Cheers,
    Erik
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Cheers,
    Erik
    Looks like it is only in .max format which only opens with 3DSMax.
    mesh would have the same license restrictions as DS and poser files, just need to check with the EULA or author.
    There was a few threads over at Foundation 3d on helicarrier WIP, but doesn't seem any were released
    Well if you can use a sea going vessel there is this model of the USS Enterprise:
    http://www.renderosity.com/mod/bcs/uss-enterprise-cvn-65-/97029/
    or a free model of the Essex:
    http://www.renderosity.com/mod/freestuff/?item_id=53674
    Charlie
    edited March 2015
    I just found another airborne one that doesn't look as much like the SHEILD one. It is in sketchup format and you will have to use Sketchup or some other program to convert it to obj or fbx
    https://3dwarehouse.sketchup.com/model.html?redirect=1&mid=4ea4bf17051433055610722e7877cbdb&prevstart=0
    and in dae format:
    http://www.3dvia.com/models/F1DA96E7F9CBDDEF/cvna-82
    Thanks for all the suggestions, but decided against this conceptual approach.
    The more and more i worked on the idea, the less and less I liked it.
    -MJ
  • pwiecekpwiecek Posts: 1,598
    Davorama's kits are once again available. Can't link because the site has a lot of X rated stuff.
    I would recommend the Capital ships carrier along with some of the addons from FVCS.
    edited March 2015
    Thanks, but Ive dropped this project.
    -MJ
    Post edited by MJ007 on
    Read that after posting
    No worries. Still appreciate the effort.
    -MJ
  • KibarretoKibarreto Posts: 38
    I'm working in this model. Perhaps, it is close to what you are looking for. Helicarrier WIP
    800 x 340 - 116K
    800 x 340 - 111K
    800 x 340 - 110K
  • wsterdanwsterdan Posts: 3,546
    I'll take it! ;-)
    -- Walt Sterdan
    This is freakin awesome! You just made me reconsider that project!
    -MJ
  • LintonLinton Posts: 543
    ETA? This looks awesome, some quick questions, can the command deck be hidden, for a smooth looking launch pad?
    And will it come with stealth textures?
    -MJ
    Too late, I called "dibs". :lol:
    While I'm at it, I also want whatever that is in kibarreto's avatar, it looks like a set of buildings on some huge, walking beast. Whatever it is, I want that too.;-)
    -- Walt Sterdan
    ETA is approx 3 months. In the pipeline after 2 models. Stealth textures? Interesting. Some parts can be hidden for keeping system resources. Command deck is one of them, thanks.
    Hi Kibart, last post about this was back in March 2015, has there been any further progress on the Helicarrier?
    Hi Linton, no, sorry it is still a WIP.
    Thanks for getting back to me about this item Kibart. Good luck with all your projects.
