Post Your Renders - Happy New Year yall
1…6162646667…100
  • bighbigh Posts: 8,147
    Few renders and animations bundled up in a video, hope ya all like it smiley
    good one - nice to see some one using C
    Howies secret lake
    http://orig02.deviantart.net/93da/f/2016/070/c/f/secretlake300framessofar_by_realmgal-d9urelu.mp4
    muic is from sony vegas content, under music, wicked somebody
    48 hours into secret lake render so far, about 300 frames.  rara estimating 222 more hours for 1500 more frames smiley
    sony vegas gnawing at my sanity
    pulled in the png sequence.  renders are pretty much crisp.
    vegas showing a lil motion blur, or something, dunnooo where it's coming from.
    i added a 2nd video track, reversed the frames i have so far to make the movie a few seconds longer,
    the reversed track not showing the blur like on the first track.
    it's the same exact renders,
    812 x 424 - 73K
  • head wax said:
    nice work FifthElement, and thanks for the headsup on the distance  falloff shader = does it work with transmaps (eg polymesh hair)  by chance?
    Yep, works fine with them, obviously, will not work with dynamic hair, you can't have everything, lol smiley
    1000 x 450 - 117K
  • magaremotomagaremoto Posts: 1,238
    MistyMist said:
    MistyMist said:
    thank you MistyMist,
    here is a couple of other outcomes by "unbiased" Iray and Fluidray; about Iray I love it, but it's pretty usual (but unusual for an unbiased engine) tweak and play around a lot to take control over shadows and albedo.
    Last but no least, another try in carrara
    Fluidray?
    the iray version barely shows the arches shadow
    the iray output is clearly overexposed but this is what I get with quick camera and light settings; realistic but flat. need to know more about iray
    about fluidray, powerful but not very fast (cpu only) and the learning curve isn't steep at all
    found this  smileysmileysmiley http://www.fluidray.com/help/
    doesn't say anything about animating.
    the render engine i  dream of is vray.  last time i checked the vray standalone renderer was 500americangreenbacks.
    no camera animation in fluidray only stills at the present; vray? many error messages and memory issues in 3ds max on my pc but great lighting quality imho; nobody's perfect anyway, look at the houdini mantra outcome (PBR kernel): wrong computation of reflections at the parapet base
    plus another shot with the beloved carrara.  May anyone suggest where to find some high quality animated smoke and fire footage for free to be used in it?
    1280 x 720 - 633K
    2000 x 1533 - 470K
  • cdordonicdordoni Posts: 584
    Thank you all for the nice words.
    This is the first time I used Sparrowhawke3D's Distance Falloff shader plugin to render depth pass, behaves much more predictable in Fusion (Depth Blur node) than Carrara's native pass smiley
    That a really good application, I had considered a method that required building a rig that would travel with the camera with a constant near and far object so that everything in between received the full range of the limited 256 greyscale values.
  • aspinaspin Posts: 219
    edited March 2016
    http://mitchmartinez.com/4k-fire-stock-footage/
    If you have Hitfilm, you could use procedural fire/smoke to comp it. Maybe it is in express version.
    Post edited by aspin on
    looks great, thank you aspin.
    I own Hitfilm but I'd rather embed a clip into my scene or maybe try particle emitters within carrara
    thanks :) no you cant have everything... but you can ask ;)
    update on secret lake render. 486 frames and still rendering.
    stuck it on utoob
    added sound effect to deepen secret lake mystery smiley
    needs a Nessie monster  tee hee
  • DiomedeDiomede Posts: 15,464
    edited March 2016
    Excellent.
    EDIT: to remove spoiler.
    Post edited by Diomede on
    Lots of cool work here. Unfortunately I can't seem to view 5th Element's video because I need to upgrade my Flash viewer, and my old system can't upgrade to the current version. Obsolescence sucks. ;-(
    Don't feel too bad for me though. I've been plugging away at a major video project in Carrara and aside from renders not being as fast as I would like, it's been going very well.
    Here's a screen capture of one of the scenes. It is not all done. I'm still rendering assets to composite. It's supposed to be a stylized Serengeti scene with Kilimanjaro in the background during the rainy season. When it is done I will be applying some paint filters to it (I kind of liked the watercolor effect). I will wait and apply the filter when all the elements are done and composited so it will be easier to get a uniform painted effect.
    All the elements are created and rendered in Carrara. I used Dartanbeck's Starry Skies for the starry sky. I used AE for the lightning.
    726 x 555 - 444K
    animated lightning always interestingsmiley
  • StezzaStezza Posts: 9,265
    edited March 2016
    did this one with the thought of putting it into the last Carara Challenge .. then changed my mind smiley
    The Old & The New
    1200 x 675 - 510K
    Post edited by Stezza on
  • de3ande3an Posts: 915
    The Old & The New
    The style of this render has a unique overall quality about it that's really eye catching. I like it a lot!
    (Although I don't quite understand why the Lone Ranger and Tonto have a Koala sidekick.) smiley
    The Old & The New
    de3an said:
    The Old & The New
    Thanks De3an, we can blame EvilProducer for the Koala being there  devil
    And we can blame Australians for Vegemite. ;-P
    yes
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,679
    Where is Tasmania? (They get very pissed when you leave em off)
  • DartanbeckDartanbeck Posts: 22,153
    Agreed! There is a lot of really cool stuff here! This scene looks intriguing! Really cool stuff - can't wait to see more of it ;)
    de3an said:
    The Old & The New
    Me too!
    bigh said:
    Bravo! Wild stuff there, bigh!
    you can't see it?
    put your glasses on Wendy lol
    ahhh and the thylacine, yes was on my iPad, my excuse
  • Lots of cool work here. Unfortunately I can't seem to view 5th Element's video because I need to upgrade my Flash viewer, and my old system can't upgrade to the current version. Obsolescence sucks. ;-(
    Well, here is YouTube link, don't think they are using Flash anymore smiley
    Very nice, as always, Fifth!!! Love it!
    Excellent! Well worth the wait!
    playin with widdershins tentacoo smiley
    gonna take awhile to wrap these around gianni6 for a hug
    and the talk show.
    1920 x 803 - 2M
    1920 x 803 - 1M
    1920 x 803 - 1M
  • DondecDondec Posts: 243
    Just wanted to try shoes... with decent accent lighting.
       - Don
    1920 x 1080 - 474K
    edited March 2016
    camping trip click to play
  • PhilWPhilW Posts: 5,162
    Wendy - I really like the mist effect, and hey this one even has a story (of sorts!).
    click to play
    no longer available but very nice in Octane
