Warrior Makeup for Genesis 2 Female problem
jakiblue
in The Commons
Anyone with this can help me out please?
http://www.daz3d.com/warrior-make-up-for-genesis-2-female-s
I've applied one of the makeups to Monique 6's face, and the makeup is completely out of whack - doesn't align correctly. See attached screenshot.
It's for Genesis 2 female, and I'm using monique who is for Gen2F, so Im not understanding what is going wrong here.
Monique has her own UVs, so if you're using her default texture that's probably the problem.
:headdesk: I totally forgot about that.
So it'll only work on skins that are G3F deault based, right?
That would be G2F UVs, but yes.
If you want to use a base skin with another UV set maybe it would work to apply them to a geometry shell? (You might need to apply a mask to make the shell transparent where you don't have the makeup)
