Warrior Makeup for Genesis 2 Female problem
jakibluejakiblue Posts: 7,281
Anyone with this can help me out please?
http://www.daz3d.com/warrior-make-up-for-genesis-2-female-s
I've applied one of the makeups to Monique 6's face, and the makeup is completely out of whack - doesn't align correctly. See attached screenshot.
It's for Genesis 2 female, and I'm using monique who is for Gen2F, so Im not understanding what is going wrong here.
333 x 213 - 58K
  • LeanaLeana Posts: 13,499
    Monique has her own UVs, so if you're using her default texture that's probably the problem.
    :headdesk: I totally forgot about that.
    So it'll only work on skins that are G3F deault based, right?
    That would be G2F UVs, but yes.
    If you want to use a base skin with another UV set maybe it would work to apply them to a geometry shell? (You might need to apply a mask to make the shell transparent where you don't have the makeup)
