Selecting several items in DAZ 4.9
Hera
Hello!
After upgrading to 4.9 I must've changed some setting which now hinders me from selecting and manipulating several items in a scene at the same time. And it's beginning to annoy me because it keeps interfering with my work.
I'm doing like this:
1. I select several items from the scene tab:
But when I check what has really been selected in the parameters tab it looks like this - only one item is really selected instead of both/ all of them:
Instead of the way I want it - like this:
It's the same way if I should for instance texturizing an object. It only de-facto select one of the objects out of many I do select.
Is there a way to fix this?
Post edited by Hera on
Open the Parameters pane (or whichever pane it is you are using) option menu (the lined button in the top corner, or right-click the pane's tab) and make sure you have Consolidate Properties checked and Show Separate Items unchecked.
It worked! Thanks a lot :)
