Selecting several items in DAZ 4.9
HeraHera Posts: 1,970
edited March 2016 in The Commons
Hello!
After upgrading to 4.9 I must've changed some setting which now hinders me from selecting and manipulating several items in a scene at the same time. And it's beginning to annoy me because it keeps interfering with my work.
I'm doing like this:
1. I select several items from the scene tab:
But when I check what has really been selected in the parameters tab it looks like this - only one item is really selected instead of both/ all of them:
Instead of the way I want it - like this:
It's the same way if I should for instance texturizing an object. It only de-facto select one of the objects out of many I do select.
Is there a way to fix this?
Post edited by Hera on
  • Richard HaseltineRichard Haseltine Posts: 111,241
    Open the Parameters pane (or whichever pane it is you are using) option menu (the lined button in the top corner, or right-click the pane's tab) and make sure you have Consolidate Properties checked and Show Separate Items unchecked.
  • HeraHera Posts: 1,970
    It worked! Thanks a lot :)
