Docking a Pane in Daz Studio
I recently changed my layout to City Limits Lite.  I like this much better as the thumbnails are much bigger and easier to see.  However, I would like to dock the render pane on the top right along with the aux view, scene tab etc.  There is room there but I can't figure out how to get it to stick.  I have tried dragging and dropping (not just on that but on the one underneath that as well.)
  • FSMCDesignsFSMCDesigns Posts: 12,847
    You could try right clicking on the pane and make sure it is set to dockable
  • frogimusfrogimus Posts: 200
    Isn't it actually a "window" rather than a "pane"?
    Maybe, but it's called pane in my DS
    474 x 336 - 44K
  • The area in which renders appear, however, isn't a pane but a separate window.
    edited February 2016
    Grab the Tab called parameters and see if it can be moved to a different pane
    EDIT: Or pane group or whatever it is called.  I realized after I posted that I wasn't replying to the OP so you may be wanting to dock the actual Render screen (which isn't possible I believe) rather than the Render Settings/Parameters.
    Post edited by frogimus on
  • IceDragonArtIceDragonArt Posts: 12,916
    Okay.  I will give some of these options a try.  In the other layout style the Render options window was part of a group pane on the left.  In this one its lined up at the top and it opens a whole new window which takes up half the screen instead of being neatly to the right or left.
