Docking a Pane in Daz Studio
IceDragonArt
in The Commons
I recently changed my layout to City Limits Lite. I like this much better as the thumbnails are much bigger and easier to see. However, I would like to dock the render pane on the top right along with the aux view, scene tab etc. There is room there but I can't figure out how to get it to stick. I have tried dragging and dropping (not just on that but on the one underneath that as well.)
You could try right clicking on the pane and make sure it is set to dockable
Isn't it actually a "window" rather than a "pane"?
Maybe, but it's called pane in my DS
The area in which renders appear, however, isn't a pane but a separate window.
Grab the Tab called parameters and see if it can be moved to a different pane
EDIT: Or pane group or whatever it is called. I realized after I posted that I wasn't replying to the OP so you may be wanting to dock the actual Render screen (which isn't possible I believe) rather than the Render Settings/Parameters.
Okay. I will give some of these options a try. In the other layout style the Render options window was part of a group pane on the left. In this one its lined up at the top and it opens a whole new window which takes up half the screen instead of being neatly to the right or left.
