What the heck happened to my menus
Nothing is where it's supposed to be. If I go into the edit menu there's no longer a Zero Figure / Zero Figure Pose option. Object only has the option to parent it to another item. Where have all the old features been moved to?
  • I can no longer even create a new light or new camera? What the hell is with this new menu layout in 4.9?
  • Is this just the way the menus are now in 4.9? I've reset things to factory default in the preferences but my menus are still completely messed up. I can't subdivide, I can't convert an object to a figure. I can't apply smoothing modifier. All the function I had in the edit menu in 4.8 are no longer there in 4.9.
    This is horribly frustrating. More and more I'm starting to wish I'd never upgraded to 4.9
  • Try switching ot another layout thne back to the one you want to reset the ui.
  • nonesuch00nonesuch00 Posts: 18,763
    No. My 4.9 is still the same. Sounds like you scrambled the default layout of the menus some how. You should open a ticket with DAZ Support. Look in these forums under the Products -> DAZ Studio Discussion and you'll see a link to contact DAZ support and open a ticket.
    Thanks! It took a few tries but I got the old layout back again. I don't know why it ever switched in the first place.
    You're welcome. That's one of those weird out of nowhere bugs that, while annoying, is usually a pretty easy fix.
  • fixmypcmikefixmypcmike Posts: 19,701
    Try running the "Update and Merge Menus" script.
    It was making me think I was losing my mind because I was "I could have sworn I used these menus in 4.9 and they were still the same as 4.8".  Good to know I'm not going crazier than I already am.
