Daz has slowed down
PatroklosPatroklos Posts: 533
Hello,
I used to be able to open a scene that I have been working on in less than a minute, now it takes fifteen minutes for even the simplest scene.
Everything to do with Daz seems to take an eternity.
No other program seems to be affected.
What can I do to get things moving again? Is there a buffer that needs clearing?
Is it the latest version of Daz?
I am currently loading a scene with one actor in it and an HDRI lighting. Nothing else. I started before writing this message, it still has not loaded.
Help would be greatly appreciated.
Post edited by Patroklos on
  • PatroklosPatroklos Posts: 533
    edited February 2016
    Part of my problem might be the external HDD I am using.
    I will start by defragging it.
    However I think an SSD might be the answer, I can put Daz Studio and the runtime, scenes an everything to do with Daz on it.
    There is something else though. Daz is constantly doing something, the dreaded revolving coloured wheel is constantly appearing when it should be doing nothing.
  • StratDragonStratDragon Posts: 3,290
    depending on the drive connection it can be a huge lag. The best scenario may be if you're going to use an SSD use it as your internal solution, not an external one and maximize it's throughput.
    a spinning wheel could be a number of things, if the drive is slow it could be processing the data from the drive or it could be another application slowing down your computer.
    What are your specs (CPU/GPU/RAM,etc.) and what else do you run when you use DS? Do you have a mac/pc? do you run Anti-Virus, or some other managment software that did not come with your OS? All these things can play a big part in performance.
    Hi Stratdragon & thanks for your reply.
    Mac (Retina 5K, 27-inch, Late 2014), Intel Core i5, AMD Radeon R9 M290X 2048 MB, 32Gb ram, generally no antivirus, I use an app called Memory Monitor and Roboform which are on most of the time, I will often have the browser open, but I have not noticed a significant performance change betweem on and off.
    if you post an etrecheck report I can take a stab at it. It will give me insight as to what is on your computer that you may or may not be aware of and it will not give anyone any private info. It was developed by one of the higher level volunteers on the Apple forums and I (and hundreds of other Mac techs) have used it to troubleshoot many macs to determine slowdowns and pitfalls.
    Roboform I'm not familiar with but if you DL'ed off CNET there is a strong possibility CNET shoved some crapware in there as a thank you for using their bandwidth.
    Memory Monitor, again I don't know it, but Mac OS manages memory and disk management and security better than anything else you can plug into it. For the most part most of a majority of 3rd party utils have been traced back to the root causes of serious OS stability issues (see apple forums) The biggest offenders are all commercial Anti-Virus (They have no preventive track record for any mac "virus" at this time), Mac Keeper (wallet-lightener-ware),  and Clean My Mac (as "Destroy my Mac" would have been too obvious)
    Otherwise you can post your questions on the Apple forums and get opinions as to what the problem might be.
    Thanks again Stratdragon,
    Etrechecheck is interesting, however the report does seem to show anything untowards - though I am far from being an expert.
    I can identify all the apps it mentions in its report. Memory monitor was purchased through the Apple store and gets 4.5 stars from 550 users, so presumable does not cause many problems.
    EtreCheck version: 2.9.6 (256)
    Report generated 2016-02-24 21:45:53
    Download EtreCheck from http://etrecheck.com
    Runtime 1:36
    Performance: Excellent
    Click the [Support] links for help with non-Apple products.
    Click the [Details] links for more information about that line.
    Problem: Beachballing
    Hardware Information: ⓘ
        iMac (Retina 5K, 27-inch, Late 2014)
        [Technical Specifications] - [User Guide] - [Warranty & Service]
        iMac - model: iMac15,1
        1 3.5 GHz Intel Core i5 CPU: 4-core
        32 GB RAM Upgradeable - [Instructions]
            BANK 0/DIMM0
                8 GB DDR3 1600 MHz ok
            BANK 1/DIMM0
            BANK 0/DIMM1
            BANK 1/DIMM1
        Bluetooth: Good - Handoff/Airdrop2 supported
        Wireless:  en1: 802.11 a/b/g/n/ac
    Video Information: ⓘ
        AMD Radeon R9 M290X - VRAM: 2048 MB
            iMac 4096 x 2304
    System Software: ⓘ
        OS X El Capitan 10.11.3 (15D21) - Time since boot: about 3 days
    Disk Information: ⓘ
        APPLE SSD SD0128F disk0 : (121.33 GB) (Solid State - TRIM: Yes)
            EFI (disk0s1) <not mounted> : 210 MB
            Boot OS X (disk0s3) <not mounted> : 134 MB
            Macintosh HD (disk2) / : 1.11 TB (877.12 GB free)
                Core Storage: disk0s2 120.99 GB Online
                Core Storage: disk1s2 999.35 GB Online
        APPLE HDD ST1000DM003 disk1 : (1 TB) (Rotational)
            EFI (disk1s1) <not mounted> : 210 MB
            Recovery HD (disk1s3) <not mounted>  [Recovery]: 650 MB
        WDC WD20NPVZ-11WFZT0 disk5 : (2 TB) (Rotational)
            EFI (disk5s1) <not mounted> : 210 MB
            disk5s2 (disk5s2) <not mounted> : 2.00 TB
            Boot OS X (disk5s3) <not mounted> : 134 MB
        WDC WD20NPVZ-11WFZT0 disk6 : (2 TB) (Rotational)
            EFI (disk6s1) <not mounted> : 210 MB
            disk6s2 (disk6s2) <not mounted> : 2.00 TB
            Boot OS X (disk6s3) <not mounted> : 134 MB
    USB Information: ⓘ
        VIA Labs, Inc.          USB3.0 Hub
                Realtek USB3.0 Card Reader
        Prolific Technology Inc. USB-SATA Bridge 2 TB
            Icy Dock (disk3s1) /Volumes/Icy Dock : 2.00 TB (1.20 TB free)
        Apple Inc. BRCM20702 Hub
            Apple Inc. Bluetooth USB Host Controller
        Apple Inc. FaceTime HD Camera (Built-in)
        VIA Labs, Inc.          USB2.0 Hub
                Canon MG6400 series
    Thunderbolt Information: ⓘ
        Apple Inc. thunderbolt_bus
            Western Digital My Passport Pro
    Gatekeeper: ⓘ
        Mac App Store and identified developers
    Kernel Extensions: ⓘ
            /Library/Extensions
        [not loaded]    foo.tap (1.0 - 2016-02-17) [Support]
        [not loaded]    foo.tun (1.0 - 2016-02-17) [Support]
            /System/Library/Extensions
        [not loaded]    com.avira.kext.FileAccessControl (1.0.0d1 - SDK 10.9 - 2016-02-17) [Support]
    Startup Items: ⓘ
        tap: Path: /Library/StartupItems/tap
        tun: Path: /Library/StartupItems/tun
        Startup items are obsolete in OS X Yosemite
    System Launch Agents: ⓘ
        [loaded]    147 Apple tasks
        [running]    89 Apple tasks
    System Launch Daemons: ⓘ
        [loaded]    188 Apple tasks
        [running]    99 Apple tasks
    Launch Daemons: ⓘ
        [loaded]    com.adobe.fpsaud.plist (2016-01-29) [Support]
        [loaded]    com.malwarebytes.MBAMHelperTool.plist (2015-12-22) [Support]
        [loaded]    com.wdc.WDPrivilegedHelper.plist (2016-02-24) [Support]
    User Launch Agents: ⓘ
        [running]    com.dxo.OpticsPro10LaunchAgent.plist (2016-02-24) [Support]
        [loaded]    com.google.keystone.agent.plist (2015-12-12) [Support]
        [loaded]    com.valvesoftware.steamclean.plist (2015-11-05) [Support]
    User Login Items: ⓘ
        iTunesHelper    Application  (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
        RoboFormIcon    Application  (~/Library/Application Support/RoboForm/RoboFormIcon.app)
        Skype    UNKNOWN  (missing value)
        Sonos    Application  (/Applications/Sonos.app)
        Mail    Application  (/Applications/Mail.app)
        Safari    Application  (/Applications/Safari.app)
        RoboForm    Application  (/Applications/RoboForm.app)
        Firefox    Application  (/Applications/Firefox.app)
        Calendar    Application  (/Applications/Calendar.app)
        Contacts    Application  (/Applications/Contacts.app)
        apple-scc-20150729-170650    UNKNOWN  (missing value)
        apple-scc-20151117-102404    UNKNOWN  (missing value)
        apple-scc-20151117-102716    UNKNOWN  (missing value)
        WDDriveUtilityHelper    Application  (/Applications/WD Drive Utilities.app/Contents/WDDriveUtilityHelper.app)
    Other Apps: ⓘ
        [running]    com.DAZ.DAZ3DIM.70432 (2015-06-19)
        [running]    com.DAZ.DAZStudio.4832 (2016-02-24)
        [running]    com.SiberSystems.RoboFormIcon.80032 (2015-12-30)
        [running]    com.apple.xpc.launchd.oneshot.0x10000020.DXOOpticsPro10 (2016-02-12)
        [running]    com.etresoft.EtreCheck.140192 (2016-02-20)
        [running]    com.google.Chrome.19552 (2016-02-19)
        [running]    com.rockysandstudio.Memory-Diag.54752 (2016-02-17)
        [loaded]    com.rockysandstudio.Memory-Diag.Launch-Helper (2016-02-17)
        [running]    com.sonos.macController.60832 (2016-02-01)
        [running]    com.westerndigital.WDDriveUtilityHelper.139872 (2015-05-19)
        [running]    jp.co.canon.ij.ica.scanner13f.81312.180FA0CE-E590-41AA-B3C4-3830EBF2A983 (2015-09-16)
    Internet Plug-ins: ⓘ
        FlashPlayer-10.6: 20.0.0.306 - SDK 10.6 (2016-02-10) [Support]
        QuickTime Plugin: 7.7.3 (2016-02-17)
        Flash Player: 20.0.0.306 - SDK 10.6 (2016-02-10) [Support]
        Default Browser: 601 - SDK 10.11 (2016-02-17)
    User internet Plug-ins: ⓘ
        CitrixOnlineWebDeploymentPlugin: 1.0.105 (2013-04-26) [Support]
        Picasa: 1.0 - SDK 10.6 (2014-08-12) [Support]
    Safari Extensions: ⓘ
        Open in Internet Explorer (2014-12-05)
        RoboForm (2015-12-30)
        SimilarWeb (2014-12-12)
        PanicButton (2014-12-13)
        TrafficLight (2015-03-31)
        Ghostery (2015-09-17)
        Translate (2016-02-10)
        AdBlock (2015-09-29)
    3rd Party Preference Panes: ⓘ
        Flash Player (2016-01-29) [Support]
    Time Machine: ⓘ
        Skip System Files: NO
        Mobile backups: OFF
        Auto backup: YES
        Volumes being backed up:
            Macintosh HD: Disk size: 1.11 TB Disk used: 237.36 GB
            Icy Dock: Disk size: 2.00 TB Disk used: 804.53 GB
        Destinations:
            Data [Network]
            Total size: 3.00 TB
            Total number of backups: 49
            Oldest backup: 16/07/2015, 07:57
            Last backup: 24/02/2016, 21:41
            Size of backup disk: Too small
                Backup size 3.00 TB < (Disk used 1.04 TB X 3)
    Top Processes by CPU: ⓘ
            96%    DAZStudio
            32%    kernel_task
             6%    WindowServer
             6%    diskimages-helper
             2%    DesktopServicesHelper
    Top Processes by Memory: ⓘ
        2.66 GB    DAZStudio
        1.95 GB    Google Chrome Helper(15)
        1.87 GB    kernel_task
        1016 MB    DXOOpticsPro10
        655 MB    Sonos
    Virtual Memory Information: ⓘ
        15.00 GB    Free RAM
        17.00 GB    Used RAM (5.88 GB Cached)
        63 MB    Swap Used
    Diagnostics Information: ⓘ
        Feb 24, 2016, 05:45:27 PM    ~/Library/Logs/DiagnosticReports/DXOOpticsPro10_2016-02-24-174527_[redacted].crash
            com.dxo.OpticsPro10 - /Applications/DXOOpticsPro10.app/Contents/MacOS/DXOOpticsPro10
        Feb 24, 2016, 05:24:44 PM    ~/Library/Logs/DiagnosticReports/DOPCor_2016-02-24-172444_[redacted].crash
            /Applications/DXOOpticsPro10.app/Contents/MacOS/DOPCor
        Feb 24, 2016, 05:24:43 PM    ~/Library/Logs/DiagnosticReports/DOPCor_2016-02-24-172443_[redacted].crash
        Feb 24, 2016, 02:07:01 PM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-24-140701_[redacted].cpu_resource.diag [Details]
            /Applications/DAZ 3D/*/DAZStudio.app/Contents/MacOS/DAZStudio
        Feb 24, 2016, 02:04:07 PM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-24-140407_[redacted].hang
        Feb 23, 2016, 10:22:27 PM    /Library/Logs/DiagnosticReports/PrivilegedAppRunner_2016-02-23-222227_[redacted].crash
            /Applications/NordVPN.app/Contents/Resources/PrivilegedAppRunner
        Feb 23, 2016, 08:00:51 PM    /Library/Logs/DiagnosticReports/mds_stores_2016-02-23-200051_[redacted].cpu_resource.diag [Details]
            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
        Feb 22, 2016, 02:18:57 AM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-22-021857_[redacted].cpu_resource.diag [Details]
        Feb 21, 2016, 10:57:31 PM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-21-225731_[redacted].hang
        Feb 21, 2016, 10:55:22 PM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-21-225522_[redacted].cpu_resource.diag [Details]
        Feb 21, 2016, 10:49:16 PM    Self test - passed
        Feb 21, 2016, 10:46:37 PM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-21-224637_[redacted].cpu_resource.diag [Details]
        Feb 21, 2016, 10:44:13 PM    /Library/Logs/DiagnosticReports/DAZStudio_2016-02-21-224413_[redacted].hang
  • nonesuch00nonesuch00 Posts: 18,884
    It is almost surely the external HDD. I have a 5 year old 2nd Gen Intel i5 with Intel HD Graphics 3000 and 8GB RAM. Using Unity 5 it would take me up to 15 minutes for my to test play my game scene in the Unity editor with the HDD but after I switched to the left over SSD from my fried PC tablet the same scene would start in about 1 minute.
    Now once it's loaded it RAM it's not that noticable in either case but the initial loading was taking soooo long. I don't remember HDDs being that slow before I had SSDs in my computer it almost seems like they have slowed them down but that couldn't be the case.
            96%    DAZStudio
            32%    kernel_task
             6%    WindowServer
        2.66 GB    DAZStudio
        1.87 GB    kernel_task
    I have now got the external SSD running, not the HDD.
    The above was run whilst a scene was slowly loading.
    The below was run whilst I was unsuccessfully trying to select a camera. The 267% surely is the problem, what is the cause of this? Daz Studio was doing nothing at this point, how can it use that much CPU?
           267%    DAZStudio
            17%    kernel_task
            17%    systemstatsd
             4%    WindowServer
             1%    fontd
        6.37 GB    DAZStudio
        1.89 GB    kernel_task
        557 MB    mds_stores
        492 MB    mdworker(18)
        12.00 GB    Free RAM
        20.00 GB    Used RAM (5.58 GB Cached)
        63 MB    Swap Used
    Its now over 360% idling!!  What is the cause of Daz Studio huge use of CPU whilst idle?
    Sorry, I missed the ssd replacement of hdd post.
    Use an xterm / cmdtool and do sudo for the ktrace command and find out how the kernel is interacting with DAZ Studio. You man need to read the man page or documentation on how to properly utilize ktrace on your version of os X. Below is a link to a very high level summery of what ktrace is but it's not useful for teaching you how to use ktrace.
    https://en.wikipedia.org/wiki/Ktrace
    Post edited by nonesuch00 on
  • Solved
    It is Iray - you must turn max samples down when using viewport with Iray, that way CPU use drops back.
    No scene loaded, viewport Texture Shaded, CPU under 1%
    No scene loaded, viewport Iray, CPU 370%
    Reduce Max samples to 5 and we are at less than 1%
    Load a scene, max samples to 5,  CPU drops back to less than 1% pretty quick.
    Damn!  All that time wasted.  Still I have a nice new external SSD smiley
    Thanks for help guys.
    Patroklos said:
    Solved
    I thought that you might be rendering but you talked like you were waiting for DAZ to load a scene...rendering can take as long as you want if you keep increasing the accuracy and detail of the render.
  • Solved one problem, but the difficulties remain utterly unresponsive, near to completely unuseable.
    Its getting worse each time I use it.
    I will raise a ticket
    Well that's a good ideal and if you want a clue as to what the cause may be learn ktrace enough to help you out.
    did this blow up when you upgraded to 10.11.3
    if your backup has 10.11.2 have you tried rolling back to it?
