Product Download
dash2128dash2128 Posts: 736
edited February 2016 in Bryce Discussion
I have a fair idea of how to do it, but I'm not quite sure of the file to place DESERT SCENE CONSTRUCTION KIT in, so that it will work in Bryce.
I like Bryce a lot, but am not as familiar with using it as I am DazStudio.
I would like to set up DESERT CONSTRUCTION KIT, and place some Daz-constructed characters in a scene, to make some test stills.
 Any advice on the best path and file to use, to ensure I can use D.S.C. KIT in Bryce?
Post edited by dash2128 on
    A link to the product would have helped.  This appears to be a compilation of different elements, so each needs to be put into the correct folder.  even if you download this using DIM I would recommend that you install it manually to ensure a correct placement.  It is a very old set, and would not have been set up for a dim installation.
    An excerpt from Horo's so useful PDF.
  • dash2128dash2128 Posts: 736
    Didn't think about a link, sorry.
    This is kind of late, but:
    http://www.daz3d.com/desert-scene-construction-kit
    Thank you!   I will give it a try.
