Product Download
dash2128
I have a fair idea of how to do it, but I'm not quite sure of the file to place DESERT SCENE CONSTRUCTION KIT in, so that it will work in Bryce.
I like Bryce a lot, but am not as familiar with using it as I am DazStudio.
I would like to set up DESERT CONSTRUCTION KIT, and place some Daz-constructed characters in a scene, to make some test stills.
Any advice on the best path and file to use, to ensure I can use D.S.C. KIT in Bryce?
1142 x 465 - 86K
Post edited by dash2128 on
A link to the product would have helped. This appears to be a compilation of different elements, so each needs to be put into the correct folder. even if you download this using DIM I would recommend that you install it manually to ensure a correct placement. It is a very old set, and would not have been set up for a dim installation.
An excerpt from Horo's so useful PDF.
Didn't think about a link, sorry.
This is kind of late, but:
http://www.daz3d.com/desert-scene-construction-kit
Thank you! I will give it a try.
