Possible error with Lisa's Climbing Vines & Ivy Textures using Connect
I wonder if someone else might be able to confirm this being an issue. I just installed Lisa's Climbing Vines and the Ivy textures through Connect using Studio 4.9 and I get an error message when trying to load them into a scene.
"One or more files could not be found while loading file: . Make sure that your DAZ Studio content directories are correctly set, blah blah"
I've installed other Lisa Botanicals products through Connect which load without issue, so it could just be a problem with these two products (or others that I do not own). Just wanted to pass that along.
Thanks in advance for any help.
  • fixmypcmikefixmypcmike Posts: 19,718
    Is this with the General Release or the latest beta?  Could you submit a bug report, please?
  • SnowSultanSnowSultan Posts: 3,822
    edited February 2016
    It's version 4.9.0.63 Public Build. I wanted to see if anyone else could replicate it before submitting a bug report for two reasons:
    * the error is unusual because I followed the link to my data\cloud\1_3140\props\plants\lisa'sbotanicals\lb_vines folder and the files are actually there.
    * I have not filed a bug report since the days when we needed a separate user account to do so, and I don't remember where we do it now.  ;)   Sorry!
    Post edited by SnowSultan on
    I think this is the error that was fixed in 4.9.1.23:
    "Fixed path resolution for *.daz based content installed to ./data/cloud folders"
    Bug reports are now submitted like Support tickets; I usually put "Bug Report" in the title.
    Oh, I didn't realize there was another Studio update. Thanks for letting me know, I will update it shortly.
    OK, I was still thinking about the old bug forum where we used different accounts and could follow progress (or lack of) towards solving it.  :)   The update will probably fix this issue though, that sounds like what I'm experiencing. Thanks again.
    edit: updated, it fixed the problem with Lisa's vines and also seemed to correct an Iray Canvases issue I was having.
