Does 'Set The Mood' work in 4.7?
WillowRaven
in The Commons
Does 'Set The Mood' work in 4.7? It's a flash sale item right now and I was thinking of giving it a go.
It seems to work properly in DS4.7. I just got it, loaded it into 4.7, and it worked; but I wasn't happy with the darkening of the figure I choose. I suspect that with some adjustments I could have gotten better results.
Anyway if you get it and don't like it, you can always return it
Thanks :D Is it hard to work with?
Sorry, I don't have enough experience with it yet to answer that. It is very easy to load and apply; but I haven't experimented with changing it from straight out of the box. I just did a quick test for you to see if it works.
Maybe, some other poster can answer the question about how difficult it may be to obtain the desired results.
Thanks for all of the effort. I've never played with special cameras before.
Found this old thread on it: http://www.daz3d.com/forums/discussion/20152/set-the-mood-question-about-rendiering which seems to suggest one might want to set the lighting to Raytraced Shadows rather than deep shadows?
Thanks. And I prefer raytraced, myself.
