mcjTransport, model/animate spline based tubes - Version 1 is out !!
24
    Wow, it hasn't been easy for you, but it looks like you got there in the end. Good thinking!
  • mCasualmCasual Posts: 4,607
    edited September 2012
    the keen eye will have noticed that in the first post, i mentioned the word "animated"
    well, each time you'll run mcjTransport, you 'll have the option of specifying a new morph name
    so you can have as many tube-shapes as you want for the same tube
    in the image below i created 3 morphs/shapes
    then i animated their morph strength
    so using this, you could have Aiko plugging her guitar's cable in the Amplifier
    as in this scene
    http://www.youtube.com/watch?v=_Dvwd8Hyh-Y
    at frame 0, // morph1 at 100% // morph2 at 0% // morph3 at 0%
    at frame 10, // morph1 at 0% // morph2 at 100% // morph3 at 0%
    at frame 20, // morph1 at 0% // morph2 at 0% // morph3 at 100%
    at frame 30, // morph1 at 100% // morph2 at 0% // morph3 at 0%
    640 x 480 - 156K
    Post edited by mCasual on
    i thought i'd have the script ready today, but there's one last and important feature i want to add
    remember the image of the road in page 2 of this thread, the road was horizontal
    in another case it was twisting a specified number of times
    i'll add the possibility to tweak the "roll" (sideway tilt ) of the road
    this is essential if, for example you want a flat ribbon to wrap around a character's arm or leg
    so ... you'll have to be patient smore
    695 x 900 - 249K
  • GreymomGreymom Posts: 1,146
    Better and better!
    These boots look terrific! It is hard to believe that it can be done in DS.
    well actually they were not done in DS,
    i was trying to illustrate, that mcjTransport could be used to create flat ribbons, that follow a character's leg or arm
    so you could make the strings and straps using mcjTransport
    the rest of the shoe would still be done in a modeler like Hexagon or Blender
    though, the shoes for A3 are available free over here
    http://www.daz3d.com/forums/discussion/4670/
    they are props, not a "real" figure but still usable
    as of this morning this is the UI
    The simplest use would be like this
    - select the number of sides and segments for your tube
    - press the "build" button
    - set Daz Studio's timeline appropriately
    - create a null
    - animate the null, which creates a path
    - press the "update tube" button
    - done
    720 x 720 - 84K
    I like the interface too. Yes, my post was a bit confusing in regard to the shoes, I only meant the straps, that was staggering enough for me :)
    When you get around to producing a script that can do shoes as well, can I be your business manager?
    so here's the last piece ( well maybe i'll add something) of the puzzle
    the "roll" of the animated marker ( the square with green lines ) is transfered to the tube
    the animation of the marker is just 3 keyframes on a 32-frames playrange
    500 x 500 - 623K
    knotty tube with (non-tiling) voronoi bump map
    800 x 800 - 128K
    800 x 800 - 72K
    Looks like a knotted hose pipe. There must be loads of uses for this script. I am really going to get into this one when it is released.
    Brilliant work!
    looks like i'll need one more day
    i added the possibility to save a path as a profile curve
    so you will be able to create profile curves without using mcjSuperLathe
    also, the profiles dont have to be closed loops ( so i guess that's no longer called 'tubes' )
    673 x 673 - 70K
    Umm....while you're at it, could you possibly get it to wash the dishes? :-)
    This is looking fantastic. Take all the time you need...
    Post edited by mjc1016 on
    i'm adding the possibility of welding the vertices at the beginning and at the end of the tube
    ( since it was available in mcjRibbons, mcjLathe and mcjSuperLathe )
    1280 x 720 - 110K
    800 x 800 - 66K
    800 x 800 - 55K
    Welding is good. It looks useful.
  • MattymanxMattymanx Posts: 6,998
    mighty impressive
  • TugpsxTugpsx Posts: 820
    You have the best collection of scripts hands down that have been presented to any community. I am very impressed witht he amount of work you have contributed to the DAZ and other community and greatful for all I have learned from you over the years.
    thanks again for sharing not just the results of your hard work, but also the knowledge of how it was accomplished and the know how to do it ourselves.
    Give a man a fish, feed him for a day. Teach him to fish, feed him for a lifetime. this you most certainly have done.
    Looking forward to diving into this new adventure.
    thanks !
    i hope the final script wont be too scary to use
    so i created a section of the UI called "advanced",
    if one doesn't touch the advanced controls
    they still can use the script, to do less complicated tubes
    a gear profile , with a non-closed 4-keyframes path ( 4 copies )
    1280 x 720 - 131K
  • SkelchSkelch Posts: 276
    This is awesome stuff Thanks!
    is today the day ? probably
    hang in there
    in the meantime here's a (cover of a) song including the word "probably"
    http://www.youtube.com/watch?v=CwvyQZ7KMtU
    hey there's a version with Prince on guitar http://www.youtube.com/watch?v=BgRLrOyxUBo&feature=related
    fig 1 is a test after i solved the issue of paths that starts non-horizontally
    800 x 800 - 49K
    in case you wonder wassup wassup
    in figure 1 you can see a tube that follows an animated marker's path
    animation keyframes are spaced 4 frames
    so, the marker positions between keyframes are computed by daz studio
    unfortunately the kind of curve used tends to overshoot
    and that's why you see ugly little kinks here and there
    in figure 2 you can see that i can impose monotone cubic splines, which dont overshoot
    and that's wassup, i'm adding monotonizing to the script
    ..... ( time passes )
    and in fig 3., the same path after monotonization
    so all this post could be called monotonization monogatari
    if you're interested in that topic, i followed this algorithm : http://en.wikipedia.org/wiki/Monotone_cubic_interpolation
    and in fig. 4 here's 256 of them
    1000 x 1000 - 115K
    1000 x 1000 - 200K
    896 x 511 - 50K
    880 x 682 - 71K
    896 x 510 - 36K
    as you could gather, the 3D path is created by you, by animating a marker
    as you could see in previous images it's possible to weld the tube ends to form a ring
    but animation curves in daz studio dont make clean loops
    so here too i'll do something about it in the script
    1000 x 1000 - 106K
  • Tempest!Tempest! Posts: 0
    Looking dandy!
  • Testing6790Testing6790 Posts: 1,091
    I can't wait to get this, try to use it, then immediately give up because it's bound to be way to complicated for me lol
    there will be a default non-expert mode
    here's the instructions for that mode
    - create a marker, for example, a primitive sphere, 3cm diameter
    - launch the script
    - select the number of sides and the number of segments for the tube, ex: 4 sides, 32 segments
    - using Daz studio's facilities, animate the marker, over the animation range of frame 0 to 32
    - select the marker and the tube in Studio's scene tab
    - launch the script
    - press the "Update Tube" button
    500 x 500 - 51K
    500 x 500 - 24K
  • TheNathanParableTheNathanParable Posts: 1,089
    Wow, this looks brilliant. Definitely looking forward to this. :)
    If you want to see the user manual as it is being written
    https://sites.google.com/site/mcasualsdazscripts2/mcjtransport
    it's also the web page where the script will be downloadable .... soonishingly
    800 x 800 - 104K
    800 x 800 - 120K
    800 x 800 - 42K
    800 x 400 - 28K
    800 x 300 - 14K
    This is seriously one facinating project. Its like finding the widget for most widget.
    Thanks for sharing your work with us.
    thanks!
    i eventually when i get around to installing the plugin sdk for DS4.5, i may port this.
    image below is the latest interface
    as i write the manual i test it and finish implementing / correcting the features
    it took more time then i thought, but it's feature-rich and can share curves with mcjSuperLathe
    1280 x 720 - 124K
  • Kendall SearsKendall Sears Posts: 2,995
    Is the plugin coded so that an extension could be written to use SVG files for path input?
    Kendall
