Overlaying an image over a Shader preset.
I am trying to overlay a jpg image over a shader preset to create a shader preset, is this possible or am I going to have to createa seperate texture map and create the shader preset that way?
  • You should be able to do it using the Layered Image Editor, assuming that ti will perform the type of overlay you want.
  • shadowhawk1shadowhawk1 Posts: 2,214
    I will have to see if I can find a tutorial on L.I.E. and see if it will work.
