DokkAlfar For Genesis 2 Can't Wear Clothes? (SOLVED!)
PipefoxPipefox Posts: 113
I'm having some trouble with the DokkAlfar For Genesis 2 Male. No matter what kinds of clothes I put on him, I always end up with huge holes in the clothes as if there is skin poke-through. I've tried the usual mesh-smoothing to get rid of the holes, but for some reason that just makes things worse instead of better. I'm not really sure what I'm doing wrong.
Has anyone else had similar trouble with this product? I'm really eager to make some dark elves, so any advice as to how they can wear their clothes properly would be very much appreciated! :)
Post edited by Pipefox on
    I'll test it out in a second.
    okay, tested him out with Darius's Air outfit, and he seems to wear it fine. Which outfits are you using? Maybe I can have it and can test it.
    749 x 846 - 56K
  • PipefoxPipefox Posts: 113
    Hi Serene Night! Thank you for wanting to help me! :)
    I've tried DokkAlfar with these clothing sets;
    Dark Passion For Genesis 2 Males
    Dark Moods for Genesis
    Onyx For Genesis Male
    I know the last two are meant for Genesis while he's Gen2, but I have converters that have worked those clothes for dozens of other Gen2 figures easily and have never had this problem before. I have a little screencap of what it looks like when I put the Dark Passion for Genesis 2 Males shirt on him. When the holes appeared I tried Smoothing like I usually would, but that either made the holes bigger or just shifted them from one location to another.
    I tried putting Dokk's skin MAT on a different figure, but then strangely, I had the same issues with the new figure!
    Thank you for testing this for me. I don't know if this is a bug with the figure itself or if there's just something weird going on on my end. :)
    979 x 663 - 697K
  • scorpioscorpio Posts: 8,533
    It could be the displacement, try applying a push modifier to the clothing.
    I'm still a little new with DAZ, Scorpio. :) Can you please tell me how to apply a push modifier?
  • Select the clothing item, then go to Create>New Push Modifier. You can thena djust the offset (in cm) in the Parameters pane.
    Thank you, Richard! ^_^ I appreciate the instructions!
    I tried the push modifier but it didn't seem to change anything for me. It was certainly worth a try though. :)
    I had a talk with my friend Nadino. We believe the issue with Dokkalfar is skin displacemnt is causing this issue. Click on DOKKAlfar, and go to his surface tab. Turn off the displacement on his skin.
    He will look much better, but you will still need to add a 10 smoothing smodifier to the shirt of Dark Passion and also adjust the fit using the morphs on the shirt. Here's the result, and a screenshot of the morphs I used to get the fit right.
    1407 x 938 - 143K
    700 x 800 - 201K
    That worked perfectly!! You are the best, Serene Night! Thank you very much, and please thank your nice friend Nadino too! Dokk looks great in his clothes now! :D
    Big thank yous too to Richard and scorpio! ^_^
    I have to say that this DAZ forum is the nicest forum I've ever been on. Everyone is so friendly and willing to help. I'm very grateful for your kindness. :)
