DAZ Dragon 3 Eye's Will Not Render in Iray
revenger681revenger681 Posts: 156
edited February 2016 in Daz Studio Discussion
Is anyone else having issues with the DAZ Dragon 3 figure rendering in Iray? I cannot get his eyes to show up in Iray. I supsect it's a specularity setting somewhere but I cannot get them to show up. They are pure white. I've done a quick render to put up here so you can see what I'm talking about. If I render in 3dlight it works just fine. Anyone know what I can do to fix this in Iray?
Post edited by revenger681 on
  • IceCrMnIceCrMn Posts: 2,333
    On the Surfaces tab. Change "Eye Surface" to iray Glass: thin , or iray water thin.  See if that helps :)
    That looks like what you get in Genesis 3 when you don't have a transparent shader (glass, water) on the Eye Moisture Surface (other figures call it Eye Reflections).
    I don't have Dragon 3 so I can't say what eye surfaces it does have, but that should give a hint as to where to look.
    I got the pro bundle yesterday while it was on sale along with Jepes dragon fire bundle,,thats how I knew :)
  • revenger681revenger681 Posts: 156
    Hey, thanks Icecrmn! Worked like a charm. So I was on the right track of thinking it was the eye surface materials. I didn't think of simply trying a preset.
    Thanks!
    P.S.
    I also got the pro package on sale. I like Dragon 3 a lot so far, just couldn't figure out why the eyes never came out right.
    600 x 600 - 492K
    You're welcome
    yep,,you were on the right track.
    Good to see you got it sorted out :)
  • Hi! Sorry to open again this post.. But I can't fix it as you done.
    I am using daz 4.12 pro and I couldn't find anything like it when you wrote. Do you remember how you did it? Which of the parameters should it be?
    Thank you
    Thanks!
    P.S.
    1026 x 1071 - 597K
  • Ok..
    Fixed like this!
    1918 x 1046 - 925K
  • Ok..
    Fixed like this!
    Just wanted to say thank you for posting up how you fixed it. I appreciate it.
