DAZ Dragon 3 Eye's Will Not Render in Iray
revenger681
Is anyone else having issues with the DAZ Dragon 3 figure rendering in Iray? I cannot get his eyes to show up in Iray. I supsect it's a specularity setting somewhere but I cannot get them to show up. They are pure white. I've done a quick render to put up here so you can see what I'm talking about. If I render in 3dlight it works just fine. Anyone know what I can do to fix this in Iray?
Post edited by revenger681 on
On the Surfaces tab. Change "Eye Surface" to iray Glass: thin , or iray water thin. See if that helps :)
That looks like what you get in Genesis 3 when you don't have a transparent shader (glass, water) on the Eye Moisture Surface (other figures call it Eye Reflections).
I don't have Dragon 3 so I can't say what eye surfaces it does have, but that should give a hint as to where to look.
I got the pro bundle yesterday while it was on sale along with Jepes dragon fire bundle,,thats how I knew :)
Hey, thanks Icecrmn! Worked like a charm. So I was on the right track of thinking it was the eye surface materials. I didn't think of simply trying a preset.
Thanks!
P.S.
I also got the pro package on sale. I like Dragon 3 a lot so far, just couldn't figure out why the eyes never came out right.
You're welcome
yep,,you were on the right track.
Good to see you got it sorted out :)
Hi! Sorry to open again this post.. But I can't fix it as you done.
I am using daz 4.12 pro and I couldn't find anything like it when you wrote. Do you remember how you did it? Which of the parameters should it be?
Thank you
Ok..
Fixed like this!
Just wanted to say thank you for posting up how you fixed it. I appreciate it.
