Double genesis (1 and 2) in poser Pro 2014 and VUE import from Poser
How do I solve this Double figure problem when I use poserCF file and Dson in my poser Pro 2014? Dson import keeps saying actors
Images removed http://www.daz3d.com/forums/discussion/3279/
Are you using the latest version of the exporter? If your goal is Vue have you tried going directly?
Like make them poser objects (pz3) or Collada (*dae)?
I would suggest trying both and seeing which, if either, works best. As I recall there is an issue using .dae with surfaces being reflective when they shouldn't.
