Anyone else notice a slight increase in RAM use age with 4.9
stump3point1
After installing the latest update I see a 5% increase of RAM. May this be due to the new content system? I also checked the task manager(I'm on an old Vista system) and can see cms(Content management system) still holding space on the RAM after I close Daz studio.
Is there any way to purge this after closing Studio or even shutting it off all together?
With only 4gb of RAM I have become a RAM mieser. Is anyone else seeing the same issue? Is there a way around it I have tried stopping CMS within Studio to no avail and my computer is offline I don't really use Smart Content that often either.
Any Ideas? Or may be go back to 4.8.
Thanks in advance.
uninstall the SQL files will stop it running; you wont be able to use smart but not an issue for me. There are two files; I'm not running 4.9, so can't tell you the names; I went back to 4.8.
That might help you RAM useage. You can at least see if it does.
The CMS service is the old Valentina CMS -- go to Services and disable it. The new PostgreSQL CMS doesnt run as a service and the processes are called postgres.exe (there are usually half a dozen running when it's active, they should close when you close down DS).
