Anyone else notice a slight increase in RAM use age with 4.9
After installing the latest update I see a 5% increase of RAM. May this be due to the new content system? I also checked the task manager(I'm on an old Vista system) and can see cms(Content management system) still holding space on the RAM after I close Daz studio. Is there any way to purge this after closing Studio or even shutting it off all together? With only 4gb of RAM I have become a RAM mieser. Is anyone else seeing the same issue? Is there a way around it I have tried stopping CMS within Studio to no avail and my computer is offline I don't really use Smart Content that often either. Any Ideas? Or may be go back to 4.8. Thanks in advance.
  • nicsttnicstt Posts: 11,715
    uninstall the SQL files will stop it running; you wont be able to use smart but not an issue for me. There are two files; I'm not running 4.9, so can't tell you the names; I went back to 4.8.
    That might help you RAM useage. You can at least see if it does.
    The CMS service is the old Valentina CMS -- go to Services and disable it.  The new PostgreSQL CMS doesnt run as a service and the processes are called postgres.exe (there are usually half a dozen running when it's active, they should close when you close down DS).
  • stump3point1stump3point1 Posts: 139
    edited February 2016
    Thanks for all the replies. I will give them a try, I did change the SQL a while back, maybe I didn't uninstall the other one. I will report back so others who are interested or are having the same issues might help figure this out.
    Post edited by stump3point1 on
  • The CMS service is the old Valentina CMS -- go to Services and disable it.  The new PostgreSQL CMS doesnt run as a service and the processes are called postgres.exe (there are usually half a dozen running when it's active, they should close when you close down DS).
    This did the trick, thanks a whole heap my friend. Is there a way to remove it from the registry? as I do have postgre installed.
