Where do I find serial number for 8.5 pro
This discussion was created from comments split from: Carrara 8.5 PRO Serial number issue.
Post edited by Chohole on
need the serial number for carrara 8.5 pro
Go to your Account, (the little blue man at top right of the forum page) and you will see "Serial Numbers" in the index line across the top.
https://www.daz3d.com/downloader/customer/serialnumbers
Also,.. You'll need to have Administrator rights on your system for the Serial number to lock in
Select the carrara program icon and choose "Run as administrator" then put the serial number in, and you'll be fine.
Hope it helps :)
3DAGE,
Will this cause the serial number to be found in "Help" or under a different menu? It does currently appear in the statup pic only.
HI John :)
No,. the serail shouldn't show up anywhere witin the program menus,. the Run as Administrator allows Windows to store the serial number,. if you're not an administrator,. the seral wil be asked for each time you load the software,. it's a Windows security thing
the start-up "Splash screen" shows only part of the serial,. for security
3DAGE,
Thanks... I hadn't realized the serial number in the "Splash screen" wasn't the total serial number, glad you pointed that out.
The partial serial number does show up in the 'About' menu.. which is the Daz logo on the top left side .. mouse over and left click & select About
but that's about it.
Thanks Stezza. Tried it and found the partial serial number. I do wonder if I've ever registered it... suspect so or it wouldn't have shown anything.
