Where do I find serial number for 8.5 pro
edited February 2016 in Carrara Discussion
This discussion was created from comments split from: Carrara 8.5 PRO Serial number issue.
Post edited by Chohole on
  • need the serial number for carrara 8.5 pro
    Go to your Account,  (the little blue man at top right of the forum page) and you will see "Serial Numbers" in the index line across the top.
    https://www.daz3d.com/downloader/customer/serialnumbers
  • 3DAGE3DAGE Posts: 3,315
    Also,.. You'll need to have Administrator rights on your system for the Serial number to lock in
    Select the carrara program icon and choose "Run as administrator" then put the serial number in, and you'll be fine.
    Hope it helps  :)
  • wgdjohnwgdjohn Posts: 2,634
    3DAGE,
    Will this cause the serial number to be found in "Help" or under a different menu? It does currently appear in the statup pic only.
     HI John :)
    No,. the serail shouldn't show up anywhere witin the program menus,. the Run as Administrator allows Windows to store the serial number,. if you're not an administrator,. the seral wil be asked for each time you load the software,. it's a Windows security thing
    the start-up "Splash screen" shows only part of the serial,. for security
    3DAGE,
    Thanks... I hadn't realized the serial number in the "Splash screen" wasn't the total serial number, glad you pointed that out.
  • StezzaStezza Posts: 9,152
    wgdjohn said:
    3DAGE,
    The partial serial number does show up in the 'About' menu.. which is the Daz logo on the top left side .. mouse over and left click & select About
    but that's about it. wink
    Post edited by Stezza on
    Thanks Stezza. Tried it and found the partial serial number. I do wonder if I've ever registered it... suspect so or it wouldn't have shown anything.
    Post edited by wgdjohn on
