ANIMATION CONVERTER V4 TO G1 Female
Hi i have just tried to convert an animation v4 to g1 it worked fine i n daz 4.8 but i now get the following error i am loading Victoria 4.2 the same as in 4.8 .But error states i have not got victoria 4.2 loaded but i have
  • Look in the scene tab and check that the name is Victoria 4.2 and that the name for Genesis is Genesis
    The names need to be exact for the script to locate them.
  • jimlinjimlin Posts: 146
    Thanks for your reply the scene tab name is Victoria 4.2 and that the name for Genesis is Genesis it works fine in pose converter
  • Send a screen shot with the scene tab open, and also the Smart Content or Content Library (Which ever way you start the script) open to the script.
    Thanks for your fast response I have found the problem i was loading from categories i created when loaded from the  folder DIM installed to works great thanks again for reply
  • Sci Fi FunkSci Fi Funk Posts: 1,198
    Hi,
    I was also having the same problem. I loaded victoria 4.2 and genesis via smart content. I get the "victoria 4.2 is not loaded in the scene. Be sure you are working with the Base Victoria 4.2 figure." error.
    What was happening is that a lower case v was being used for victoria 4.2's name. I was about to post here when I noticed the caps were different, so I post here just in case someone else has the same issue. The fix then is to capitalise the leading v so "victoria 4.2" is "Victoria 4.2"
    Cheers.
    351 x 93 - 14K
