Gia 7 Thread
1235»
  • Beautiful Toyen. Thanks for sharing.
  • ToyenToyen Posts: 2,048
    Thanks guys!
    RamWolf it is a bit adjusted, the default appears to be too matte for my taste.
    So what I like to do is to adjust the glossy settings a bit.
    I did not save this scene so I cannot tell you the exact settings, but what I usually do is:
    - switch the shader mode to "Weighted"
    - adjust the glossy roughness to something between 50-70 and set the glossy weight (usually to a small number), also remove the glossy maps
    - do the same thing for the top coat but the roughness should be lower, below 50
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,659
    edited February 2016
    first proper render on my fixed computer reinstalled with the newest version of Daz 4.9 just a simple one only lights used are the hdmi from the iray worlds skydome and didn't play around with any settings so yeah I'm liking the new Gia 7
    3840 x 2880 - 1M
    Post edited by ANGELREAPER1972 on
  • RAMWolffRAMWolff Posts: 10,373
    Toyen said:
    Thanks guys!
    Thanks.  I'll look into that.  I do notice that when I select the Weighted that the Glossy Roughness is hidden
    Yes I believe that upon switching to the "Weighted" mode, the glossy slider is set to 0 - turned completely off so you actually have to go in and adjust it to your liking.
