Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
For the past 5 years you have been able to get a choice of SLI and Crossfire onthe same board. The more disturbing thing I have seen is boards that support AMD processors don't support PCIe 3.
I said it they had it, but that it usually doesn't work as well as dedicated support boards.
Wait, AMD boards that don't support PCIe-3.0????? That's just crazy.
Each of the Motherboards that I use in built machines, both work and home, support both CrossFire and SLI. Intel did the bridge (I forget if it is North Bridge or SOuth Bridge. LOL)
If you can find a board that supports both an AMD processor and PCIe-3 I would love to see it. Though those MOBO's that support AMD processors don't look like they have advanced much in the past 5 years. Probably because, unlike the Intel Boards, the AMD boards are processor backwards compatible, which limits advances.
Oh well, we are getting way off topic. :)
Not really...because the motherboard/CPU combination is very relevent to render speed...
And here's all I could find with PCIe-3
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007625 600474769
Way off topic. :)
Oh, and the SABERTOOTH 990FX/GEN3 R2.0 has PCI-E 3.0. But I think it's the only one.
edit: Oh, and it looks like the ASRock X79 series has PCI-E 3.0 as well....
Everything I have seen about N-Link seems to target servers and workstations more than consumers. And regardless, I'm not sure how that would work for DAZ when it doesn't even support SLI yet. You'd still get the benefit of the extra CUDA cores, but I don't think N-Link would offer DAZ a significant speed increase.
I believe HBM2 will be the major game changer. You get more RAM and it is much faster, too. The cards will feature more CUDA cores that are even more effecient. These are the two biggest hardware constraints by DAZ, and I think a single flagship Pascal has the potential to blow people's minds at DAZ render speeds.
The reports about Pascal having shortages are a bit premature. Those are purely based on the lack of a working Pascal prototype at Nvidia's conference. It is concerning, but not something to worry about just yet. AMD has announced they are shipping their new GPU line this fall. Nvidia would not want to get beat to market by AMD, especially when these AMD cards are expected to be major upgrades (they are also using HBM2 and 14-16 nanometer fabrications.) So even though AMD has only 20% market share right now, they can bounce back very quickly and pull a large portion of that share back if they can beat Nvidia to the market. AMD also has a new CPU on the way, and it is supposed to be a major upgrade.
No matter what happens, this much is certain: 2016 will be an exciting year for PC hardware.
It's not Daz (or more specifically Studio) that doesn't support SLI...it is Iray that doesn't and if there were any support for SLI it would need to come from Nvidia and it does not seem that they are interested in providing SLI support for Iray.
In regards to the issue of the CPU having 28 vs 40 PCI lanes and impact on rendering speed in multi-GPU systems, I found this info from Autodesk's Iray FAQ ( http://area.autodesk.com/blogs/shane/the_iray_faq ) :
Q. How much slower is a GPU placed in Gen1 x8 PCI Express slots versus in a Gen2 x16 PCI Express slot?
A. For operations that are constantly updated, like viewport interactive graphics, Gen1 is much slower than Gen 2. For compute-intensive operations that keep the GPU very busy before sending its results across the bus there is nearly no difference between the two PCIX types. In the case of iray and GPU ray tracing, you might see a GPU render faster on a Gen2 slot when the scene is very simple, but nearly no difference on a Gen1 slot when the scene is reasonably complex.
It appears then that DAZ IRay viewport updates could be impacted by slower pipe, and possibly simple rendering scenes, but for more detailed scenes the flow over the pipe probably not a big issue. Still, it would be nice to have the screen redraw fast, even if it is a bit of a luxury to work in IRay viewport rather than in Texture Shaded. Now with this info I can at least try to justify the additional cost for upgraded CPU, i.e. improved screen redraw of complex IRay scenes.
The Pipes are also Motherboard dependent. Make sure your MOBO handles the lanes you are expecting to use.
Okay so I want to make sure I am reading this correctly... Using the CPU and the GPU together is slower than just the GPU alone?
Sometimes!
I tested this on my old system (an old phenom X6 with an old 550ti) with an old test scene:
CPU - 19minutes
GPU - 8.5minutes
Together - 5.5minutes
I concluded, its when the GPU is much faster than the CPU that the load balancing fails and a 'slow' CPU can hold back the GPU.
Okay well "slow" is a reletive term my CPU is a Intel i7 930 @2.80Ghz my GPU is a 2GB GDDR5 ...just trying to figure out if I should be using both CPU and GPU or just GPU (or if I should have photo real and interactive checked differently) also trying to figure out if I should have OptiX Prime Acceleration checked or not....
You didn't actually say what GPU you have.
I've had no reason to turn off Optix so far.
That is highly scene dependent. Time to actually render vs. time to load the scene onto the card.
So far the only reason to turn off OptiX is with some computers with AMD/ATI cards it is reported to slow down the render. (I have never seen it, but it is reported to do it.) IN cases where you either have an NVIDIA card, or have an Intel GMA chip to drive your graphics, OptiX is a magic go faster button.
Most scenes will not use the 2GB video card you have, at least out of hte box. 2GB may or may not fit one figure, with clothing and hair and an HDRI for lighting. (It can go either way.)
SO does that mean I should have every thing checke then?
Oh sorry I though ti Had it's a NVIDIA GeForce GTX 750 Ti 2GB GDDR5, but is sounds like I should being rendering with all boxes check?
Keeping in mind it is definitely scene dependent, as a general rule, yes.
