Goz Installing to Wrong Path
Angel_2232633Angel_2232633 Posts: 1,204
I am trying to get GoZ installed, but when I install it. It goes to Program Files > DAZ 3D 2
That is an old directory for Daz 4.0 and it does not give me the option to change the directory in the install process. How do I fix this?
Yes, it is the most up to date version of GoZ. I just redownloaded it today.
Post edited by Angel_2232633 on
  • If you use the Install Manager you can set the paths in the Applications tab of preferences (gear icon at top-right). If you are using the stand-alone installer, Mac or Windows and are you using larger than default fonts? If you are using large fonts, put the cursor in the folder name box (assuming that comes up), hit tab once, and then hit the space bar - if I am remembering correctly that will open the folder selection dfialogue, which was hidden by the layout accomodating to the larger fonts.
