2 Items Ready to Install in DIM
inquireinquire Posts: 2,464
edited July 2016 in Daz Studio Discussion
I'm using DAZ|Studio v 4.8. So, I'm not sure if I should install these two items, or wait until I upgrade to D|S 4.9. In the DIM, under Ready to Install, is given Genesis 3 Starter Essentials Mimic,
and Bryce, Carrara & DAZ Studio Iray HDRI. Should I install these two items into DAZ|Studioo 4.8.0.59, Macintosh 64-bit version, with Mac OS X 10.11.5 running?
Post edited by inquire on
  • Richard HaseltineRichard Haseltine Posts: 111,844
    The first is, I think, Mimic configuration files for the Geensis 3 figures - those are useful only if you use LipSync (in Ds 32-bit) or Mimic Live.
    The latter, which is presumably some kind of HDRI set supporting the listed applications, is probably something that will work in your version - it should be content files, and I'm not aware that the behaviour of HDRI has changed to cause issues. However it isn't clear exactly which product you are looking at.
  • inquireinquire Posts: 2,464
    OK, thanks for the comments, Richard.
    Another questiion: those above two items are in the Ready To Install window of the DIM. If I don't want to install them, and just want to get rid of the installers, how do I do that?
    edited July 2016
    Right-click in that pane and deleet the files, then right-click in Ready to Download and use the Hide sub-menu.
